DeWitts Radiator /Spal Fans - Ground Strap
I understand its a good thing to ground the radiator with a braided strap. Where did ya'll get the ground strap and what length/width did you get? Also - where did you connect the ground from and to.. thanks
any suitable wire could be used. but i think your best bet is to get a sacrificial cathode form summit(or others), as a way to prevent corrosion. and with the newer antifreeze formulas, i wonder if that's needed.
John
Thanks Jefft/John....
Jeff - I saw one other CF member with a braided ground - looked real nice - that's why I was hoping to get the ground strap.
John - why does that have an affect when the temp unit is in teh radiator (and mine is). I will probably ground it where the headlamp harness grounds at the front left area of the core support.
John - why does that have an affect when the temp unit is in teh radiator (and mine is). I will probably ground it where the headlamp harness grounds at the front left area of the core support.[/QUOTE]
kaiser,
Because the radiator is (probably) sitting on rubber cushions and connected to the engine with rubber hoses - rubber doesn't conduct electricity.
Regards from Down Under
aussiejohn
kaiser,
aussiejohn
