What is this?
Old Apr 26, 2010 | 05:37 PM
Ryan Kitchen's Avatar
Ryan Kitchen
Default What is this?
So, i was tinkering around, and I found some loose hoses with some sort of broken valve (i'm guessing).
What do these go to?
Old Apr 26, 2010 | 05:44 PM
...Roger...'s Avatar
...Roger...
Thats part of the the headlight bypass vacuum.
Pulling down on the valve will raise the headlights
Old Apr 26, 2010 | 07:10 PM
corvetteload's Avatar
corvetteload
Depending what year you have, there are at least one valve (Headlights), or 2 for the wiper door on 68-72. They are on a bracket dead center under the steering column, if you have a year with the wiper door, there will be an electrical switch **** between the valves. Looks like this:
http://cgi.ebay.com/ebaymotors/1968-...ht_1682wt_1167
This is missing the valves which go in the big holes on either side of the switch.
Old Apr 26, 2010 | 07:12 PM
corvetteload
Heres a complete one:
http://cgi.ebay.com/ebaymotors/Corve...7#ht_500wt_956
And the valve:
http://cgi.ebay.com/ebaymotors/1968-...#ht_500wt_1182
These allow you to open the headlights without turning them on to replace bulbs, and also opens the wiper door to replace blades
Old Apr 27, 2010 | 03:55 AM
Ryan Kitchen
I've got the bracket. So what are the implications if I just leave them disconnected w/o the valve? Will the headlights just always come up? or will it cause loss of vaccum (which I am already having an issue with, could be the cause?)
Old Apr 27, 2010 | 06:37 AM
corvetteload
Absolutely will cause vacuum leak, get the parts, repro or original, buy an Assembly Manual and put it all back together. The manual will show you which line goes where, all your lines are color stripe coded, easy to do..................
WHAT YEAR IS IT?????
To What is this?
