Chrome bumper broken mount... options?
Old Aug 21, 2010 | 08:05 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default Chrome bumper broken mount... options?
So it took me FOREVER to get this front bumper off and that was due to the bolt in the bumper had broken it's welds and was just spinning. Took a lot of stuffing things down in there and spinning the hell out of the bolt to get it out of there. Believe it or not an olive cocktail fork was the tool that actually worked and got the bolt separated from the nut.... who would have thought.
I guess my only options i can think of are:
1. Buy new bumper. Mine is in pretty okay shape and I don't plan on spending the money for a new one.
2. Take it somewhere and have them cut out the old bracket, weld the nut back to it, then welt it back to the bumper...
Old Aug 21, 2010 | 08:22 PM
Skip Burney's Avatar
Skip Burney
If you cut the bracket off and try to reweld it back to the bumper you are gonna ruin the plating on the other side. I would make a small plate with a tapped hole in it and then drill a couple of 1/4 inch holes in the bracket, then slip the plate behind the bracket and plug weld the holes to hold the new tapped plate to the existing bracket. That way you won`t burn the plating off the face of your bumper. You could cut the flat face of the bracket with the hole off and reweld a nut on the back side and tig weld the small piece back
Old Aug 21, 2010 | 08:24 PM
z10kl's Avatar
z10kl
Why did you need to remove it?
If it is in good shape I would run a tap through it and run the bolt through a die so it threads real easy. JB weld the nut on and put it back on. Any welding will probably mess up the chrome.
Old Aug 21, 2010 | 10:03 PM
texaswilkins's Avatar
texaswilkins
Take the old square nut into Ace hardware and get a new one. Wiggle it in where the old one was and reweld it. If you can't weld take it all to your nearest muffler shop and they will tack that nut to the bracket for you.
Bill
Old Aug 21, 2010 | 10:06 PM
PUNISHER VETTE
The car when i bought it had a bra on it that went through this bolt. I had cut 99% of it off but there was still some stuck on this bolt.
I also plan on painting the car within the next year or two and this would have gotten in my way at some point...
I have zero welding equipment but my work does. I might be able to use that stuff but then again i've never welded anything so i would probably have to ask one of my bosses who does know if he could help me... Or I could try on my own and see how that works out!
Old Aug 21, 2010 | 10:23 PM
Skip Burney
this isn`t something you want to learn on, I don`t think you can weld a nut on the back of that in place without ruining the threads. Take it to someone who can use a grinder to cut the flat piece of the bracket with the hole from the 4 welded corners then get someone with a tig/heliarc machine to tack a new nut on the back of it and then weld it back on where you cut it
Old Aug 21, 2010 | 10:28 PM
RobRace10's Avatar
RobRace10
You could a nut plate that would be held on by pop rivets. I know they make bigger sizes. Use them all the time on race cars.
Old Aug 22, 2010 | 01:27 AM
PUNISHER VETTE
That nut plate looks like it could work and be just what I need. Only problem is finding one and then finding one in the size i need.
I was also thinking an automotive speed nut might work but after looking at the gap i have i highly doubt i can fit one.
Old Aug 22, 2010 | 01:36 AM
highschool67's Avatar
highschool67
Drill the hole big enough to force fit a 3/8 hex nut into place and tack weld the exposed edges. Grind it back and you are done.
Old Aug 22, 2010 | 07:05 AM
Woodsters's Avatar
Woodsters
Default JB weld
As "texaswilkins" said, pick up a new nut at Ace. Slather the nut in JB Weld and put it in place. Let it harden adequately. Run a tap through it to clean the threads. Use anti-seize when you put it together. Done.
Old Aug 22, 2010 | 06:07 PM
PUNISHER VETTE
I had a rivet gun handy and at the hardware store they had 1 nut plate that fit to the T.
I figured i'd try the nut plate first as it was the easiest and if it did fail I could always fall back to tac welding a regular nut onto the back area after cutting into it.
So now is this good enough you think? Should i have my boss tac it in as well in a few spots? Or I could drill another 2 holes at the top/bottom and put in 2 more rivets if that would make it more secure?
Old Aug 23, 2010 | 07:11 AM
PUNISHER VETTE
anybody? Should I go ahead and tac weld it in place as well?
Or are these two pop rivets probably good enough?
I'm unsure of what kind of force this thing takes...
Old Aug 23, 2010 | 08:19 AM
RobRace10's Avatar
RobRace10
Yhe nut plate should have been on the back side, not the front. I would tack weld it in if you are going to keep it on the front side just watch your heat so you don't blue the chrome.
Old Aug 23, 2010 | 04:55 PM
PUNISHER VETTE
There wasn't enough of a gap on the top/bottom to be able to fit the entire nut plate behind there. Same goes with the automotive speed nuts.
Seems like every option involved cutting a large chunk of the bracket off(but not the whole thing) and welding it back on with a new nut.... Which is a ton of work for something so tiny without the proper tools or skills....
Old Aug 23, 2010 | 05:07 PM
BBCorv70's Avatar
BBCorv70
Seems like this fix would cause the bumper to seat a bit off, like having a shim.
Could you cut only one side of the bracket, bend it up enough to get a not in there and welded, then bend it back and weld the bracket?
Old Aug 23, 2010 | 05:34 PM
PUNISHER VETTE
I don't think it'll make it sit all that much off but I haven't put it on yet...
There are plenty of options that I can do if i'm willing to cut and weld. I just don't want to go that option just yet as it would mean spending time and money on something I don't feel is all that important?
I mean how much force does this thing actually take? It's got 3 other bolts holding it on in other spots so I guess my plan is to put it back on like this, see how it looks gap wise, then seeing how well it holds up. If anything it might just strip right out then i'll know for sure i'll need to find a better method to attach it.
Old Aug 23, 2010 | 06:38 PM
RobRace10's Avatar
RobRace10
If you cut the threaded portion of the nut plate down, say half the threads, would it then slip in? That would be way stronger than just the rivets. The rivets are just to keep it in place they are not meant to take the load.
Old Aug 23, 2010 | 06:52 PM
PUNISHER VETTE
yeah. I understand that pop rivets are not very strong.
I guess I can look into cutting on up and see how small it needs to get before it'll fit down in the hole without me having to cut anything.
Old Aug 23, 2010 | 10:09 PM
DZRick's Avatar
DZRick
Just thinking out loud but couldn't you use the original nut and just drill 4 holes through the mount then just tack weld it back in place through those holes?
To Chrome bumper broken mount... options?
