Licence plate on tru flex 1976 bumper
I replaced my 76 bumper with a tru flex one from Willcox. The two raised front bumpers on the front are slightly closer together than on the urathane original. I now cannot put back the black metal licence plate backing because it does not fit between the bumpers. So i tried to put the licence plate directly on the bumper. The plate fits bu itself but not with a frame, and it looks odd without a frame. Anyone else with a truflex got any ideas?
I had the exact same problom when I did my 75. Got so fed up with the terrible fit I just gave the thing to a body shop. They had to grind out quite a bit of material to get the liscense bracket to fit. Its just another thing in the long line if reproduction parts that isn't quite right.
Why the hell would they make a reproduction bumper and change the dimensions anyway? Did they think that we would not want to use licence plates? Idiots grrrr
I dont want to have to get it modified now, as the paint job has just been completed, so I guess I will have to just use the plate without a frame. Pity that after tens of thousands of dollars restoring the car, it gets let down by its licence plate! My recomendation would be dont touch Tru-Flex after market parts
I'm not really sure how small the difference is but figured you could maybe use looking at the problem from a different angle.
Good Luck
Funny thing here in Wisconsin is that those frames are illegal. I've been ticketed for having one. In no way is that meant as an excuse for Wilcox but you may not want to use a frame if it becomes an excuse to get you pulled over.
Jay
Jay
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
C3
I saw this thread about an hour ago and we have a newly installed Flexy glass bumper on a car in our shop. So.. I snagged a NOS lic. plate bracket and headed out with the camera to see if there was a problem.
The license plate bracket is a very tight squeeze between the two bumper extensions but as you can see below it did fit! I then went to a 79 we have here on the back lot that is a parts car and compared the two measurements and the license plate brackets.
The bracket should measure 12.25" from edge to edge. But, the bracket on the old original cover and the new one installed both fit very, very tightly between the bumpers. I really didn't find any issue aside from it being such a tight squeeze.
Is there a chance the bracket sides are bent a bit?
Also, if you want to mail your old license plate bracket to me, I can put it in the mill and take off say 1/16th or 1/8th from each side no charge. It's not a problem at all and this might solve your issue too.
Let me know,
Willcox Inc.
Let me know,
Willcox Inc.
C3
Let me know,
Willcox Inc.
Let me know,
Willcox Inc.
Thanks Willcox for looking in to it for me, I appreciate your assistance.
Former Vendor
C3-
I can mill the bracket for you.. it's not a problem and will only take a few minutes if you want to send it to me.
But what I can't figure out is why the one we installed is the same measurements. I didn't put a tape to the two, but I plan on this tomorrow.
The bracket did fit very.. very snug... and the one in the shop is in primer.. not painted.. I know Toledo makes these on a mold and I wonder if the one you have could have maybe an extra thick jell coat on it or something.
I've installed this cover for years and I don't remember ever having this problem. But then again, we don't have front license plates in Indiana...
Willcox
Willcox
C3-
Willcox
Willcox
Done and done!
Thanks Willcox for your tips. I ground the sides off (the thin flaps on either side that stick out toward the licence plate) using an angle grinder and repainted the backing plate. It is still a VERY snug fit, but a fit is a fit.
Licence with frame sits between the bumpers now and all is right with the world.
Kev
Kev
Former Vendor
This is interesting to say the least! I'm going to let the manufacturer know for sure and see if something can be done in the future.
Willcox
Willcox
