1972 LT1 Alum. Valve covers
Do the "original" 1972 LT1 Alum. valve covers have a the rubber push in "Oil" cap or the twist on oil cap. I see most of the aftermarket covers have the twist on caps.
I have seen original pictures of Survivors that had the push in Oil cap. Were the originals polished to a high shine?
I am leaning toward the rubber one as being correct myself based on pictures that I have seen. Haven't seen any aftermarket retailers offering the ones with the rubber plug type. all seem to be twist on.
1970 LT1 'OIL cap push in
370 hp 1970 LT1 crate engine, purchased Summer 1970 Dexter Chevrolet $612.00....Part of my continued HP upgrade for my 62 FI Vette. As GM put more HP in the small block engines the 62 was a beneficiary. This is correct as to components external and internal. The 'Oil cap is a push in and is printed "OIL" in the center, not a twist in...see below it should answer your questions.....
Received 2,878 Likes
Hi #72,
I don't think the original valve covers were polished at all, certainly not to a high shine like you see now.
I've not seen the 71/72 style offered in reproduction, so I think a used set is your best chance.
Regards,
Alan
Regards,
Alan
nope, not polished. In fact I dont think any OE aluminum valve covers for GM were polished. See my pictures above....Some chrome steel covers were available in lue of painted covers on select applications however.
