Im looking for a frame to replace my rotten 74 frame. I went to look at a 73 frame today. It looked really good except there was some minor flaking in the rear kick ups where the trailing arms go. I was thinking I could weld a patch in the hollow to fix this (lots of good metal left). Added some pics, all you can really see once the flakes were removed were a couple of small holes. I was thinking Ill probally have issues with any frame I look at this old. Comments?
I have a 73 project going and we just stripped the frame of all parts. I have a frame/fab expert coming over to evaluate my "issue"...that being rust holes near the drivers side kick-up. Once he gives me the price/verdict I will know if we're going to fix or buy a replacement. Personally, I'm OK with buying replacement sections or having him fab new parts. If that's not an option then I'll start shopping the southern states. There's no point in trying to find a parts car (frame) here in Michigan. (IMO)
If there are holes in the trailing arm pockets there may be other rust issues in the differential crossmember. I would do some banging on that frame with a pointed hammer to see if there are any other weak spots. If there are a lot of thick scale chunks in the inside of the frame the metal has thinned quite a bit and may not be strong enough structurally even if it's not rusted out.
Anyone consider a new frame? I found a posting in the C2 section where a statement was made that this vendor bought the original tooling from the supplier for GM. Complete frames are available as well as pieces.
I looked at those but that price is more than Im looking to spend.
While I understand budgetary considerations, you also have to consider A) your personal safety; and B) the cost of the other parts/components/systems that could be jeopardized by a questionable frame.
I don't know what the cost of that particular frame is, but isn't there an outfit by the name of Collier Technologies that's also re-popping C-3 frames?
First I've heard of them. Frames available in stainless as well....
