Radiator Removal
Old Mar 12, 2011 | 04:12 PM
Deacon Don's Avatar
Deacon Don
Default Radiator Removal
So I have to remove my radiator. Years ago I had it repaired but it's leaking again. I do rememeber it being a pain in the rear, but I can't remember the best way to remove it. Does it remove from the top or bottom? My car is a '72, 4sp, no air.
Any advice would be appreciated.
Old Mar 12, 2011 | 04:25 PM
7T1vette's Avatar
7T1vette
You remove it from the top. But, it's a 'piece of work' to do with the body on the car. It is best that you have an extra set of hand to do this job. And, it is easier if you remove the hood first so that you have unrestricted access. Mark the locations of the hood bolts so that you can reinstall it easily.
Old Mar 12, 2011 | 05:56 PM
Alan 71's Avatar
Alan 71
Hi,
I think it's a good idea to cut a piece of cardboard to size and tape it to the front and back of the core. This will help protect it while you pull it out and put it back in.
Good Luck!
Regards,
Alan
Old Mar 12, 2011 | 06:19 PM
Deacon Don's Avatar
Deacon Don
Thanks guys. Gonna tackle it next week.
Old Mar 12, 2011 | 07:32 PM
DO2G's Avatar
DO2G
Originally Posted by Alan 71
Hi,
Good Luck!
Regards,
Alan
Great idea
Old Mar 12, 2011 | 10:54 PM
hwcoop's Avatar
hwcoop
I seem to remember having a heck of a time getting the fan shroud/rad past the upper control arm bolts.
After I removed the hood I had unbolted the rad support to the point i could tilt t 90 degrees...still a pain in the rear.
Just no room by that control arm bolt...
To Radiator Removal
