1970 coup what engine belongs in it
New member. Read alot of posts. This is my first question. Looking at a 1970 coup. Would like to know how to tell what engine should be in car. vin # 194370S405663 which I think tells me its a chev corvett coup 1970 built in St.Louis. Do not have engine # but it has a 454 in it but that still would not tell me if it is correct engine for car. Any help thanks Gary.
They didn't start using engine codes in the VIN until 72.
You need to look at the front passenger engine pad area of the block. If you are standing by the right front tire, look down where the head meets the engine block. You should see 2 groups of numbers. One will tell you where/when/and for what the engine was built for, and the other will contain a serial number matching the serial number of the car it was built for. This second number should end with the same numbers as the VIN (in your case - 05663).
Not a guarantee it's not a restamp made to appear to be the original.
Other clues are the hood, same as found on the LT1.
Tach should red line at 5600 RPM (going from memory).
Differential has caps holding the u-joints to the differential, not u-bolts.
Rear sway bar. Wider radiator and support, 27 1/2 inches. Any of these parts could have been put on to make it appear to be factory.
Are you looking for a numbers car or just wondering if it may be a big block upgrade?
Received 1,468 Likes
Cruise-In II Veteran
The VIN will not tell you which engine was originally in the car.
You can check what is in it now. There is a pad on the block at the front of the right head. Engine code (large characters) and VIN derivitive (small characters) will be stamped there. AIR and AC can make the pad difficult to see and you may need to clean road gook off of it.
69 big block shown; 70 pad stamps will be similar.
If it's a true BB car, it should have a rear sway bar, though that could be installed at any time. I also believe the caps on the universals on the 1/2 shafts are heavy duty, and not bolted on with a strap.
I'm sure 70 BB owners will chime in with other tell tale signs.
As stated above, Check the numbers on the pad & windshield pillar.
This is an early build, 5 thousand, six hundred and sixty third, (5663), built in February.
Post some pics, which can help members give you good feedback.
Good luck.
Glenn
Good luck.
Glenn
Post pics and me and other '70 big block owners can comment. 70 BB owners are a relatively small club with only 4400 or so made. There's also a few early/late '70 clues to look for such as reverse lights being concentric patterned rather than cross-hatch. BBcorv70 & GD70 have highlighted the major differences for sure.
The engine that should have or would have been in it would be 1 of 4 possible.
either a 350 engine that was rated at 300, 350, or 370 HP. the 300 and 350 had a rochester quadrajet carb and the 370 HP had a holley carb. the big engine it might have had was a 454 with rochester quadrajet and chrome valve covers.
4 possible engines, hope that answers your question.
there are many different observations that one could see that would narrow down what engine may have come in the car.
the main ones are spring rates, radiator size, radiator support size, tachometer redline, fuel line characteristics, size and presence of front and rear stabilizer bars, and how the half shafts are bolted to the rear end yokes. others include hood, tag on the shifter console, documentation of the car, owner testamonials.....
1
It's sequential number 5663. Probably built shortly after mine, 5512. Can't tell from the VIN whether it was built with a 454. Check the stamp pad in front of the right cylinder head. It should have the last six digits from the VIN stamped there, 405663... OR was it the last five digits? 05663?
Senior Member since 1492
What does the tag on the console say? Although that can be replaced too.
All 1970 Covettes were factory equipped with 370HP LT-1 350 motors just some have now been changed out for different motors over the years
You need to look at tach RPM redline, fuel lines, differential among other things to determine a motor application for a 70 Vette. If there is a transistor ignition amplifier on the front driver's side ahead of the radiator support, you might have hit the jackpot on your Vette.
Post some photos of your Vette for all of us experts to look at and we can better steer you in the right direction.
Check the pad on the engine block when you go. Take a notepad, pen, and a small flashlight.
