Garage Fumes
Garage Fumes
Wanted to know if anyone installed a through the wall garage fan in their garage and how it worked out. I don't mind the fumes in the garage but half the house smells and the wife doesn't really like it.
Received 1,468 Likes
Cruise-In II Veteran
What are you smelling? There shouldn't be anything noxious with a C3 sitting in a garage with the engine off.
If there is an actual smell, you need to determine where it is and where it's coming from.
I agree with Mike. Something is leaking pretty badly to produce a smell in the garage AND the house. Check all fuel lines (rubber and steel) carefully. You don't want to try out your homeowners' insurance!
My recent experience was a bad diaphragm in the fuel pump. Gasoline puddled when the car was sitting. The car still ran so the hole/rupture in the diaphragm must have been very small but it really did raise a stink. I replaced the pump and the two "S" hoses leading to it and now all is well.
i would put in a exhaust fan .they are on a thermostat.but you can over ride them when needed.http://www.amazon.com/Ventamatic-CX1...0910290&sr=8-2
Possible sources: old/cracked rubber fuel lines at fuel pump and/or fuel tank...don't forget the 'stuff' on the driver's side on many C3's; defective or cracked/broken fuel separator (on fuel tank); bad 'plumbing' on the fuel vapor canister; plugged-up PCV valve; pinhole leaks in the fuel tank [caused by micro-rusting of the tank]; wear-thru rub spot on a metal fuel line that is beginning to leak; loose fuel fitting; defective fuel pump; leaky carb [inside, outside, underneath, etc.]; vented fuel cap on a car designed for a non-vented cap.
Thanks guys. Will look for at those things when I get home later. How long after you run your car does the engine stay hot? Mine (haven't timed it but) must be staying hot for well over an hour and I have been assuming that is normal because of the cast iron block.
I drove for two hours this morning. Ambient here today is 90*F, a bit much for me so I came home. Cool down will take about two hours where the valve covers are just warm to the touch. That is with the hood up in the garage. Leave the hood down and that time is prolonged.
Another question - with the gas cap lid raised but the gas cap closed tight should I be able to smell gas very strong? Would think not because it isn't vented.
There have been a number of threads on high oil psi. I am not competent to say good or bad. Some like the "performance" pumps. But I can quote my owner's manual:
"Readings of 30 to 40 psi may be considered normal during moderate road speeds of 35 to 40 mph with the engine at proper operating temperature."
The pic was taken at high idle and very close to operating temperature of 180*F and you can note the oil psi. Earlier today with hotter oil that psi would have been about the same in moving driving conditions, dropping to 25psi in Drive and at 550rpm (red light or stop sign).
If you just bought your car, you may have engine degreaser and or paint fumes from a detailed/repainted engine. These smells may linger for a short time, and of course are more noticeable if you're not used to them. Make sure they're not gasoline fumes. A gasoline leak is very dangerous, especially with a (non-electric) home water heater located in your garage.
70 is not an issue, but I like to know why. If the engine has been rebuilt in the past, it is likely someone installed a higher pressure pump. Also, what weight oil do you run? A higher viscosity oil (i.e. 20-50 vs 10-30)., will run higher pressure. Like the other posts state, check fuel hoses, obvious leaks, etc. I had pin holes in the top of my gas tank where the tank had rubber to keep it from rubbing. Every time I filled the tank, the gas smell was real strong. If I had a low tank level, it wasn't too bad. I removed the tank, thinking I needed to change gas hoses but found I had tiny holes in the top of the tank. I installed a new tank and no more smell. It isn't bad to change out if you need to. Just make sure it doesn't have much gas in it if you pull the tank.
wheels
Lance
[QUOTE=centralcalvette;1578157721]If you just bought your car, you may have engine degreaser and or paint fumes from a detailed/repainted engine. These smells may linger for a short time, and of course are more noticeable if you're not used to them. Make sure they're not gasoline fumes. A gasoline leak is very dangerous, especially with a (non-electric) home water heater located in your garage.[/QUOTE
Engine wasn't recently detailed or painted. I do have a natural gas hot water heater in my garage and was concerned about that. When you remove the gas cap is their supposed to be anything (like a rubber seal or something) or just a big hole the size of your cap where you can literally see the gas in your tank?
St. Jude Donor '11
I seem to have a leaky carb. (inside). When I shut the hot engine off, I can hear it drip. I'm assuming it is hitting the hot intake and then the gas fumes come up through the air cleaner. Stinks up my garage. So I just bought a fire extinguisher and ordered a carb. rebuild kit. You may see me on here in the future after I take it apart and can't get it back together again
