1970 Stingray Corvette, 454 and 390 horsepower-- Headlight and windshield wiper help
My headlights and wipers do not work. i have no clue what to replace, actuators? relays? wiper motor?
you start with the basics, first get a vacuum diagram for your car.
Next test your current vacuum your car pulls, normal is around 18 "
around 10" things won't work very well, got power brakes ?
do your headlight and wiper over-ride switches work ?
Hit this link, it does a great kob of explaining how your vacuum headlights work.
http://forums.corvetteforum.com/c3-t...tem-works.html
Scott
Scott
Received 2,878 Likes
Hi A,
I'll also suggest that you buy a vacuum pump with a gauge, like a Mity-Vac. It really helps in testing each component individually so you can narrow down the problem.
It's well worth the cost.
Regards,
Alan
If you can describe what works and what doesn't you'll can get some suggestions on the forum too.
Regards,
Alan
