76 radiator removal
Old Oct 11, 2011 | 09:15 PM
Tim H's Avatar
Tim H
Default 76 radiator support removal
I see 3 bolts down each side and two on the bottom and the solid bar in the middle.
Will it come right out?
Old Oct 11, 2011 | 09:43 PM
MelWff's Avatar
MelWff
you remove the fan, the hood, the 3 bolts on each side and the bar in the middle. You loosen but do not remove the 2 bolts on the bottom.
Old Oct 12, 2011 | 11:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the assembly instruction manual (AIM) and take a look. You are likely to have AC plumbing to fiddle with.
FWIW: the radiator support is a major structural component for the front clip. After you remove it, make sure no undue weight is placed on the nose.
Old Oct 12, 2011 | 12:14 PM
BKarol's Avatar
BKarol
found this post from a few years ago. Might help:
http://forums.corvetteforum.com/c3-t...r-support.html
To 76 radiator removal
