Dash lights out
Old Oct 26, 2011 | 09:31 PM
Tecdiverfl's Avatar
Tecdiverfl
Default Dash lights out
took my 70 out for a ride this evening and all the dash lights are out. If its not the fuse I would assume pull the switch next?? any other suggestions what to test?
Old Oct 26, 2011 | 09:40 PM
SD71VETTE's Avatar
SD71VETTE
Check the headlight switch.
Old Oct 26, 2011 | 11:57 PM
jesse10886's Avatar
jesse10886
Does the switch still work the center gauge lights? My circuit board went and I lost all dash lights but my center gauge and shifter plate lights would still dim or brighten by the switch removed speedo/tach found the board to be very brittle and cracking into pieces every where replaced an got all my lights back
Old Oct 27, 2011 | 04:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by jesse10886
...My circuit board went...
No circuit boards in a 70.
IP fuse or bad rheostat on the headlight switch.
Old Oct 27, 2011 | 09:06 PM
Tecdiverfl's Avatar
Tecdiverfl
I will check fuses first over the week. I would asume I can jump the reostat to check the lights
To Dash lights out
