Removal of Parking Brake Console
I'm replacing the carpet and a few other interior pieces while I will have everything taken apart.
I'm having a helluva time getting the ebrake console removed. Anyone have any tricks/tips to getting this done?
There is a bolt "hidden" in the rear storage compartment. It goes through the luggage stop bulkhead, into the rear of the parking brake console (it will be under the cardboard bin of the center storage compartment). Look or feel behind the luggage stop bulkhead, above the tunnel, and you should be able to find the bolt.
You can reach the bolt from the right hand storage bin (where the jack is) if you take the liner out (if it's still there). It's fiddly but do-able and beats taken out the whole compartment with the risk of breaking it.
Nick
Nick
Received 1,469 Likes
Cruise-In II Veteran
It will help with your new carpet, but is not a How-To.
Received 2,878 Likes
Hi d2,
Nick is right that you can reach the bolt from the jack compartment.
I use a 1/4" drive socket and it's pretty easy.
Here's the hole in the bulkhead the bolt passes hrough.
Regards,
Alan
Regards,
Alan
Thanks guys. I was able to get the bolt out last night. A whole lot of cursing along the way wondering why someone would put a bolt in such a God-forsaken place. Also got a bunch of scratches on my arm in the process but its out. Now on to running wires for the new radio and amp before insulation.
Oh yeah, I know what it does but it seems like there should've been a "better" location or an alternate location for a bolt to secure the console. Regardless, its out.
