I have a blue 69 vette and my engine gets vapor lock, I was wondering if you guys could recommend a front spoiler that will help me cool down the engine or help with vapor lock. If you have any other info on how to stop vapor lock that would be great, I was thinking of wrapping the fuel lines in some sort of high temp insulation and wrapping the carburetor in it as well. what do you think of that? thanks
Have you checked the gaskets under the carb? I know on my 69 427/390 the insulating gaskets under the carb are extremely important in keeping heat out of the carb.
not sure about the gaskets I will check that thanks,
A thick insulating gasket may fix it. A coiled wire or 'spring' is around some pump to carb lines.
Expect you know a front spoiler helps at speed & won't help at idle...
The Indy ft. spoiler designed for our Vettes w/ wind tunnel scoops up air for cooling, cleans up airflow underneath & sweeps the airflow around the front tires.
Rec. for all performance 68-79 ! I put factory 3 piece on as soon as possible, so early that the paint matches & it appears original.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I experienced that problem with my previous 68 shortly after purchasing it. The fuel line wasn't stock and was poorly routed and laid on most of the intake manifold. Once I properly routed the fuel line my vapor lock problems disappeared!
A coil of wire around the line adds mass and surface area to the outside of the fuel line. This "finned" surface area dissipates heat better than a flat surface. That is why some brake lines have springs around them and why you see fins aroudn air cooled engines. An old trick we used to use is put a bunch of wooden close pins on the fuel line. We had to do that on an old pull truck with a 454 in it. Whenever we were pulling the race car in extreme heat, the truck would vapor lock. The close pins actually helped. They look kinda funny, though.
interesting. is there any reason why I should not use some heat shielding tape around the fuel lines? would the tape trap heat in or would it keep heat from getting to the fuel lines? not sure how heat tape works exactly. and would I be able to wrap the carb in heat tape as well?
I had this issue with my 72 LT-1 years ago. I put a heat shield plate and gasket under the carb and that helped. I also installed an electric, draw through, fuel pump at the gas tank and never had another problem. I love the extra pump when getting the car out in the spring. Just hit the switch and listen for it to fill the carb then start it.
