72 rear door jamb switch mount help
I am missing the threaded plate that the rear door switch screws in to. It's held in with two pop rivets but I can't see how to access the area to replace it. Thanks
Mike
Mike
Received 2,878 Likes
Hi Mike,
Sorry! There is no access!
The access panel that's in the front of the rear wheel well gets you close, but not quite there.
A member posted a cure for a problem similar to yours late this spring... maybe June. I know his real name but can't remember his forum name.
If he doesn't see this thread soon, I'll e-mail him to reply.
Regards,
Alan
Regards,
Alan
Thanks Alan,
That is what I suspected . I would appreciate the work around from your friend. Just a quick additional question. Do you know a vendor for the shoulder harness mounting plates that rivet to the body in the rear wheel well?
Have a Merry Christmas
Mike
Mike
Received 3,139 Likes
On the inside of the car, behind the quarter trim there is a few slots that lead into that cavity (where the switch goes from the harness into that plate.)
You might be able to fish a new plate in through there using wires, strings, magnets, the force, etc.
With a bolt or something from the outside, threaded into the switch hole in the plate you could hold it in place and rivet it on.
I can't remember what size thread the switch is but a pop-rivet style of threaded insert with the right thread from the outside would be almost UN-noticable
Here's a link of how they work
http://www.sporttruck.com/techarticl.../photo_05.html
Good luck
Mooser
Good luck
Mooser
MISTERZ06 (05-01-2017)
Hi Mike,
I e-mailed him.
Regards,
Alan
My wife spent a few years in Grand Rapids, (her family is from GR and Holland), and we pass through it each summer on our way to Manistee and the big lake.
I e-mailed him.
Regards,
Alan
Thanks guys!
Mooser, I monkeyed around for about 15 minutes and gave up any hope of wiggling a piece down there. I'm not a surgeon although I did stay at a Holiday Inn last night. I like that threaded nutsert. I'll check if they have the correct size.
Alan, Thanks, I'll wait for your friend to chime in. We moved here from Pittsburgh about 26 years ago. I still love the 'burgh, but this is a special area with our own west coast and up north!
Mike
Mike
Door jam switch retainer problem - advice
Hi Mike. Alan emailed me, telling me that you were experiencing a problem similar to one I developed on my car just 2 weeks before it was to be judged at this past summer's NCRS National Convention. I've copied/pasted a link to the thread where I shared my solution. There are others there too. I can report that to date, my repair is working flawlessly and looks 100% correct.
http://forums.corvetteforum.com/c3-g...challenge.html
Good luck. Let me know if I can provide additional advice, and for sure let us all know how it turns out.
Best Regards,
don
Best Regards,
don
Thanks Don,
I'll give it a try and let you all know how it turns out. This was a real "headscratcher" for me.
Mike
Alan, Thanks for your help!
Mike
Hey Guys,
Thanks for all your great ideas! I decided to use phclub's idea.
Made a bracket from a crossbar for an electrical box. It has 3/16 -24 threads. shaped to fit with rivet holes 1" coc.
Used a wire through the switch hole into the body mount pocket. Hooked the plate, pulled it tight to the backside of the body, aligned the rivet holes and... done!
I'll touch up the rivets later.
Thanks again everyone this forum is great!
Mike
Mike
Glad to hear you found a solution. I attached the link so that you'd see there are several fixes that have been used.
In my case, I had good rivet heads and didn't want to disturb the paint on the rivet heads or the door jambs. If you are OK with replacing and painting them, I think the bracket solution is a more certain fix.
redrdstr72,
I agree with you on keeping the rivets. It would have saved a bit of work but the rivets on the passenger side were missing so I had to deal with touch up anyway.
Thanks again for your help!
Mike
Mike
Hi Mike,
All's well that ends well!!!
Regards,
Alan
Regards,
Alan
Re-looping an Old Thread For a New Fix
Hi all. I was contacted by fellow member MikesRed68 for some help on this issue and I want to help him out. I need your help to help Mike.
See my post (#7), linking to a fix I did on my car in 2011. Where I used a bezel nut and adhesive to make the fix, I think that since then, one of the Corveette vendors has introduced a repair bracket. This bracket looks to be a great fix if the mounting rivets from the original bracket are missing. If they're still in place, I'm thinking that the bracket might possibly be cut down to allow its use without removing and replacing the original rivets.
Can anyone point us to who is making this repair bracket? I'd appreciate it and I think Mike will too!
Thanks in advance,
Don
Thanks in advance,
Don
door ajar bracket
Thanks in advance,
Don
Thanks in advance,
Don
Your new plate will never fit as shown, you will have to shave it down to a diamond shape, 7/8" to fit thru the hole from the backside, make a jig on your bench to shave it down.
Take you a stiff wire, pass it thru the top hole in the door jamb and into #3 BM cavity. Double knot the string fast to the stiff wire and pull the plate up tight. Then tie the string to the door striker to hold it in place. You can now screw the switch into the plate to keep the new plate from falling down into the black hole.
tie the string fast to the door striker
set your lower rivet after you have screwed in your new switch to the plate
set the second rivet
unscrew the new switch and go get a beer after you pull the wires thru, you can hook the wires up later. 45 minute job.
any q's? Give me a call, Pm for my #.........have fun
2018 C3 of Year Finalist
Mike,
This may be obvious but if you never drilled out a "pop" rivet, this may be helpful. In the top photo you can see the steel center post (mandril) of the rivet before it was pulled. The rivet puller tool will pull on the stem to compress the backside of the rivet against the frame, then cut off the stem at the top of the rivet head. If pulled properly, the remainder of the stem remains in the rivet thus providing structural integrity of the set rivet.
To drill out a pulled rivet, first the steel stem must be removed by using a narrow center punch (or something similar) to poke it through the back of the rivet. Once that is done, all that remains is the soft aluminum shell of the rivet that is easy to drill out. Normally a size 30 drill or a slightly larger ⅛ inch drill can be used to drill out the rivet head. Note, for larger rivets, you may have to use larger sized drill bits. Sometimes the hollow shaft of the rivet remains in the hole. Just take the center punch and poke it out or carefully run the drill through the hole.
If the rivet "spins" when using the drill, have someone hold the tail end of the rivet with needle-nose pliers.
If you attempt to drill out the rivet without removing the steel mandril first, the drill may walk off the rivet head and onto your paint job.
This may be overkill of a simple procedure, but that is how it is done on aircraft.
MikesRed68 (05-02-2017)
Mike,
