It's in....
It's in....
for now Spent more time than I care to admit fitting everything, getting hoses routed, and modifying the harness for the Auto Meter gauges. But it's in and attached to the D/S dash pad. Now I just need to get the nuts on the bottom studs started
It's a repo console & the center gauge panel has the single DIN adapter which wraps around the bottom. The studs are barely long enough
And with the lights on
Next weekend I'll test everything & work on getting the top dash pad in.
Thanks for all the tips
Jim
Jim
Instead of those studs being "short", could it be that the lower console is not moved fully into proper position? Also, if the bracket/brace to which those studs attach has slotted holes, just start the nuts onto those studs, THEN slide the lower console over them. With those nuts started already, it is much easier to get a 1/4" ratchet/socket on them to tighten. Remember to just snug those nuts up; if you try to lock them down, the studs will break off of that flimsy pot-metal bezel.
The radio plate wraps around the bottom adding a 1/16" or so plus the repo console is pretty thick, much more than an original. Tried to install with the nuts just started, but had no luck. Are the studs pressed in or are they threaded in? Toyed with the idea of replacing them with a longer stud but was afraid to break it, cause then I'd be
blueray72 - The gauges are Auto Meter C2's and I did install their dimmer also. Using the headlight switch the dash lights were either on or off, no dimming.
Twinray - I was outside most of the day in a Tee shirt. Big difference from last year at this time. Hoping it stays in the the high 30's low 40's a little while longer. Of course my hands are a little beat up from working on the dash for two days
Jim
Received 2,878 Likes
Hi Jim,
Looks VERY cool!!!
The reflection of the gauge light in the gaule bezels is pretty neat looking!
Regards,
Alan
Looks VERY cool!!!
Regards,
Alan
I replaced the nuts with a couple of rod couplers from the hardware store. Makes installation much easier.
Man I am really digging those gauges, speedo and tach in a black interior Shark! Seeing several recent reso-mod projects with AutoMeter and they really pop!
The studs are part of the bezel casting. I do not know whether the threads are cast with the part or if they are chased after the bezel is cast; I suspect the latter.
I suggest that you do what you can [or need to] to make the lower console fit flush with the bottom of the bezel, so that there is no gap left between them. You may have to shim, or install spacers or extend the mounting brackets from tranny tunnel to lift the console a bit more. Otherwise, you will have an unsightly and weakly supported console/bezel assembly.
Good luck.
Good luck.
Good luck.
Good luck.
The console & the reinforcing bracket are loose so they can come up to the gauge panel. Also needs to shift toward the back of the car about 1/4"
Jim
