Radio has a whining sound; changes with engine rpms
My radio has a whining sound that changes with the engine rpms. Is it a grounding problem?
Freddie
Freddie
Its a common problem in lots of aftermarket installs done in even newer cars. Make a new ground from unit to a solid place on frame or battery normally cures it.
Received 1,469 Likes
Cruise-In II Veteran
there are capacitors that you can purchase that are designed to eliminate the RF interference. all the grounds in the world won't eliminate the interference.
As mentioned, this is a common problem. Not sure if still do, but Radio Shack used to sell a filter kit, with an inductor and capacitor. Places like Parts Express, may sell these too. Maybe check with the forums electronics/audio section, while at it.
