fan shroud
Old Mar 29, 2012 | 01:55 PM
jesse10886's Avatar
jesse10886
Default fan shroud
do i need it will my car overheat without it? my 79s shroud is broken all to hell and is there but barely if i remove it completely will the fan loose its tunnel effect and not be able to pull enough cool air across at idle or in traffic? i live in so cal where the traffic makes you want to jump off a bridge! when i lived in mo an had a broken plastic shroud i would just removed it b/c most of my driving was long distance at at least 50mph so i never had an overheat issue. here it is differnet what do you guys think?
Old Mar 29, 2012 | 02:08 PM
The Spark's Avatar
The Spark
Your fan will not pull air through the radiator as effectively without the shroud. So if you are driving slow or stop-n-go traffic on a warm day, your car may overheat.
You will see many early cars without a radiator shroud. As cars got smaller grills and more horsepower, engineers worked to improve cooling of our cars. So I'd say you probably need a radiator shroud. Chevrolet didn't put them on there for looks.
Old Mar 29, 2012 | 02:14 PM
MrJlr's Avatar
MrJlr
Old Mar 29, 2012 | 02:15 PM
jesse10886's Avatar
jesse10886
thanks ss that is what i figured i would here but you never know if someone comes on an says other wise i need to freshen up everthing under the hood of my car it looks pretty sad but for me driveability and safety come first so i am doing supsension rebuild first then all new brake lines then new fuel lines, trans cooler lines and then make the hood/interior look pretty
Old Mar 29, 2012 | 02:43 PM
MrJlr's Avatar
MrJlr
But.....I got the DeWits alum. rad/fan combo....fans were already mounted and original shroud not needed.....easier and looks WAY better under the hood...!
Oh.....cools WAY better too !
Old Mar 29, 2012 | 02:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Include a replacement shroud and seals as part of your "driveability" efforts.
Might also be a good time to have the radiator cleaned/cored if it needs it.
Old Mar 29, 2012 | 02:55 PM
qwank's Avatar
qwank
If GM put it on there, it's because they absolutely could not make it work with out it
Old Mar 29, 2012 | 04:47 PM
MrJlr's Avatar
MrJlr
OR.......it was the cheapest solution.
Old Mar 29, 2012 | 05:17 PM
jesse10886's Avatar
jesse10886
MrJlr
how much do they charge for that set up how ling did it take to hook it up what turns on the fans? is it just the thermostat temp sending unit? i would think it was just a power ground and a thermal switch right?
Old Mar 29, 2012 | 05:56 PM
jesse10886's Avatar
jesse10886
thanks oldalaskaman got to ask the wife i am WAY over budget. while it is easier to ask forgiveness than permission i over did it about 5500 dollar recently lol
To fan shroud
