Trailer pics: how I mount up
Terrorizing Orange Cones
Everyone has their way in getting various things done. When it comes to towing the car, I'm fortunate to reach in my tool box and grab the trailer.
While the motor & trans are out, I wanted to clean up the engine bay and rear axle at the 2 dollar car wash.
Got in hurry and didn't get any ramp shots loading or unloading; I'll see what I can do to remember next time. This is how and where I secure the car to the trailer and thought you guys can see where I leverage designed spaces.
I use a strap around the front crossmember for the hook on winch cable. After the car was pulled up, I hook the front frame horns through the OEM supplied holes with these nifty combo J-T hooks.
Then I hook the rear with J-hooks at a convenient location. I use this corner even when the car is running due to accessibility with the sidepipes. I am aware of the slotted holes along the frame but the J-hook diameter is a tad large to fit.
I have clearance issues with the front spoiler so I use a couple of 2"x10" s for a little less stress on the spoiler from the strap. I'm going to bolt another board layer together to raise it up again and that should relieve the stress all together. I'll leave a 4" or 6" lead on bottom layer so it graduates in height.
Out back, I crisscross the straps to the D-rings to preload the chassis from an angle. I pull everything tight from this end.
Once the straps are all cinched down, then I relieve about 1/2" of slack on the winch cable for the ride.
If this was a ride longer than 20 minutes of duration, I'd pull over someplace safe and convenient to recheck the tension on the straps from initial load. Afterwards, I check strap tension at any reason to stop: fuel, grabbing a bite or bathroom break. I've never had one get loose or God-forbid, anything behind the truck's tailgate passing by or creating a NASCAR-style yard sale behind me.
Back in the shop, all cleaned up and ready to accept more parts.
Hope that helps and let me know if you have any questions. I'll offer what I can.
Good Luck.
Good Luck.
Now that is a clean engine bay. I thought mine was clean, now I realize its not....
I have a question, where is yer engine and trans? What happened?
I got mine in not that long ago. Still working on tuning.
Yanked the motor because a couple-three things ganged up and I decided to take advantage of the cold months to investigate.
Not having had a hydroboost before, I inadvertently overfilled the power steering pump. Drove around for days before realizing and coated the surrounding area in a nice film of pwr steering fluid. Rats. I picked up a lot of dust and dirt. Siphoned the level back down and cleaned what I could get to but it was never to my satisfaction. Now, it's much better.
Also have motor oil consumption issue that needs fixin'. I'm down to the short block and hoping to find glazed oil or compression rings in a hole; maybe the gaps lined up too, I don't know yet. What I do know, for a motor with around 15K miles, it shouldn't have been using as much as it was.
Oh, and I got it a little too hot the last time I ran it. My fault. Discovered a faulty radiator cap was no help but I failed to check coolant level one morning and remembered when the gauge told me, that I'd left the expansion tank dry. Oops.
Since I have the tools, space, and some time I decided to do a teardown inspection and see for myself, what the hell did I do?
At least, it was an excuse to show you my new tow hooks, eh?
St. Jude Donor '08
Excellent ideas, thanks!
I really like the stance of your car, can you please share the info about your rear suspension/tires info? whats the wheel size, width, backspace, tire size, and whether you use a offset trailing arms or stock?
The wheel/tire information are in post #'s 23, 27, 41 and 43 in the following thread:
http://forums.corvetteforum.com/c3-g...-pictures.html
The trailer was purchased without and after the vendor received the air dam order I had placed, I picked it up and later installed it along with the aluminum cargo box. I have a 4500# Superwinch mounted inside the box to facilitate loading and unloading while working solo.
Thanks for the questions, guys. Let me know if you have others.
St. Jude Donor '09
Excellent set up and pics. IMHO, far too many incorrectly tie down cars via the tires or suspension components allowing the car's suspension to travel separate from the trailer. I've always been taught to tie down the car so it travels with the trailer.
Thanks for posting the pics! I've recently bought an enclosed trailer that I'm looking to set up for hauling to remote events. I just ordered a Superwinch S4000SR, ratchet tiedowns, & strap connectors. I've been waiting for the weather to clear up enough to load my car and see how to go about securing it since she sits pretty low. Your pics really helped to get me thinking about it more.
Where did you get the hooks from?
Hi Ray,
A box trailer is certainly in my sights but before bringing one home, I need a bigger truck.
My current rig is maxed out from a rating standpoint: 7000lbs max capacity on the trailer and I only have a half-ton LWB truck with a small V-8 gas motor and auto trans. It's ok for now but I do have better security for the car and support gear in mind, down the road.
The hooks were bought from a travelling vendor last Jan. during an annual swap meet in Denver. I believe that local trailer supply or maybe a ranch supply store would have a selection of hooks along with various internet suppliers. I'd venture that big-rig truck stops may also have them available.
Hope that helps.
Hope that helps.
Any good winch manufacturer has got to be better help than pushing or pulling dead weight. Not to mention an increase of the safety factor.
Like Ray Y., I chose to buy and mount this bad boy. Makes this part of the hobby so much easier:
I drilled the round access hole you see in front of and right of the Superwinch script for the 25' controller lead (coiled, left) to plug into the unit.
With removable fenders, ingress or egress can be made normally, through open car doors as opposed to Dukes of Hazzard-style, open windows.
