69 Small Block Pre Bent Stainless Fuel Line Install with Body On?
Hi
I am about to put the fuel lines in, they are the stainless prebent (pre bent) lines and some people say it cannot be done, others say you have to cut and splice the lines, others say you can indeed slowly get the lines in as a one piece unit.
Please advise, any helpful hints would be appreciated. I would rather not have to cut the lines, but will if I have to...I definitely am not going to take the body off.
Thanks, Tim
Thanks, Tim
I have tried with the car on jack stands.....cant be done
Maybe on a lift ?..... but I still doubt it
The problem is the area where the frame kicks up by the rear floor pan
Worth a try everyone gets different results!
lines in, made a clean spliced on both with fittings, cut each line near rear floor where it hooks up over frame..came out decent
thanks for the pm's and response
