69 seat question
The foam is disintegrating.
When I had the foam replaced, it just didnt make any sense to me to not put brand-new covers on if all the time and expense was going to happen anyway. I ended up opting for black leather. Looks a zillion times better. Opting for the original vinyl would not be terribly expensive.
There are thin sheets of foam sewn into the covers to give the covers the pleated definition. That's what has deteriorated, and why the covers look the way they do.... loose and saggy.
It's not the thick seat bottom and back foam bolsters. They're easy to replace once the covers are off.
Some people say the sheet foam can be replaced....I'm not so sure.
Regards,
Alan
This is what the back side looks like. You're seeing the linen that covers the foam on this side.
It's a single foam sheet that the cover is sewn to to give the pleat it's shape.
I ended up rebuilding the original seat covers because they were in such good condition. That was almost 7 years ago and they are still in great shape.
I have put together a write-up about how to do this job; it has lots of photos to show exactly what to do. This is a job you can do, if you have any DIY skills, at all. If you want me to send you a copy of the write up...and some photos of how mine came out, send me a PM with your e-mail address.
You have got to see 7T1's info about replacing the thin 'scrim' foam in the covers.
It actually looks like he's done it.... with excellent results!?!?!
Regards,
Alan
I developed a process of slitting the original scrim foam cloth backing near one end of the channel strips, sucking out the remaining foam dust/clumps with a ShopVac and crevice cleaning tool, then re-stuffing those channels with new 1/2" thick scrim foam. It was a little laborious, but not too challenging to do. The most difficult part was to be very careful NOT to tear the 40+ year-old cotton backing cloth when vacuuming or stuffing in the new foam.
Once the new foam was slipped into the channels and the seat covers were cleaned and reinstalled on the seat frames, the final result was as shown below....
In that last shot, you can also see the seat belts that I rebuilt from the original hardware and new seatbelt webbing. That includes remaking the sewn-on nylon tags with the manufacturer's info!
If anyone needs the write-up on the seatcover rebuilding process (because they are actually doing theirs), just send me a PM with your e-mail address and I will forward my MS Word document to you.
The issue... Looking at your covers they appear to be stretched a bit and just doing the foam there is a chance the old covers will fit loose in the seat bottoms.
IMHO,
Willcox
