Speaker/Interior Thread. Need Options, and Pics!
#41
Hey Dose11 your familiar with my install.... It's OK...to upgrade I would have got a 4 Channel and ran some dash speakers and added some tweets in the kick panels......also a small sub in the jack storage maybe...
it sounds pretty good.....we hardly ever listen to the stereo anyway, But we have one now that you can't see at all and it sounds good enough for our use.....it's kinda of a trade off......either really good sound and no storage and modified look....or acceptable sound with a clean look and what little bit of storage you had to start with......well, good luck and have fun with it.....
#43
I thought I was going to wait til this fall/winter as well...and still might but I really want to upgrade the stereo, and I have a feeling there might be some funny business going on behind my dashboard with the wires...Sooo even though I don't want to...I might put the vette on the shelf for a week and do the whole interior!!! I am going to try SOOOO hard to just do the interior...
#44
http://forums.corvetteforum.com/album.php?albumid=2513
Just finished this up. I have two Infinity KAPPA 462.9CFP in the dash, two of the same behind the kick panels, two JL Audio 8W3V3-4 8" subs and two Infinity KAPPA 42.9I in the back. I mounted a JL Audio XD700/5 amp underneath the jack tray. I ran the four speakers and the two subs off of the amp and let the deck handle the two 4" speakers in the back. I'm pleased with the sound and the preservation of storage. Also, aside from the deck and peeking your head way in the back, everything still looks stock. Good luck with your decisions.
#45
#46
Absolutely. You could put just about anything back there. That was only the second fiberglassing job that I've done. I was honestly a little apprehensive about working with fiberglass and doing something like that, but I was very impressed with how easy it was. Highly recommended.
#47
#48
#49
Pretty much any fabric store. I've also heard of guys using T-shirts, pantyhose, etc. I'm just more of a fan of fleece because it has a decent amount of elasticity and it still soaks up a good amount of resin. That seems to makes it a more rigid setup to start glassing on.
Be sure if you are putting multiple speakers of different sizes in your box, i.e. a subwoofer and a coaxial, make sure you mold around the speakers to accommodate different air spaces. You wouldn't want your subwoofers trying to punch a hole through your other speakers. Not to mention very bad quality sound.
A "Tools and Materials Needed" list off the top of my head:
- Tin foil - to make your mold around the wheel wells and back of your box
- Masking tape - to tape your foil down and to mask off the area very well (do me a favor and don't ruin your carpet, ha)
- Approx 1 gal. of Fiberglass resin (depends on how many layers you want to do)
- Fiberglass matte (don't remember how much I needed.)
- At least 10 of the cheapest 1"-1 1/2" paint brushes you can find
- A reusable, "bendable" quart size mixing cup (it's easier to get the hardened resin out of the cup)
- A quart of bondo (I personally like the kind with the fiberglass in it, but I believe any kind will would)
- Sandpaper - if you're covering it with carpet, you don't need to go 2000 grit or anything, but if you're planning on painting, obviously you'll need a little finer than 60
- Wooden dowels (I recommend at least 1/2" just for strength)
- 1/4" MDF - to cut your rings (Some say 1/2', but I'm thinking that's a little excessive)
- hot glue gun (to glue your dowels and rings into place)
- Depending on how fancy you want to get with angles and such, you'll need a can of spray adhesive to spray your fleece so it'll stick to your rings and the back of your mold (obviously you'll need some if you're covering with carpet)
- Sometimes a staple gun is handy to staple your fleece to the back of your mold once you stretch it around
- Razor blades -to trim the fleece and carpet
- A dremel, cutting bit on your drill or any other suitable tool to cut the holes out of your box for the speaker(s) as well as trimming the edges of the fiberglass during the process.
Being that I have a day job, chilluns and I usually party on the weekends, as well as having to wait for resin and bondo to dry, it took me a couple of weeks. Im sure it can be done quite a bit faster, but don't expect to have it done in a weekend with good results.
Let me know if you have any other questions. I'm excited to see how your boxes come out. Good luck.
#50
In all honesty, I don't have this down to a science yet and I don't have the setup do get them done as quickly as I'd like. I've only done a few custom boxes. I'll have to post what I did in my '75 Blazer. Unfortunately, I would have to charge more than anyone would be willing to pay to make it worth my time. I was kinda doing it as a one off deal and not planning on going into business...
But, on second thought, if enough guys wanted to get a set, I might go for actually spending the time to get my act together. I could at least get a discount on bulk materials...
#52
#53
Did you try a heat gun on the wrinkles? I am not sure how it will work after being glued. I have some vinyl ordered I was going to use in a the bar/box cabinet. I hope its works if not I probably go with the painted look.
#54
I certainly didn't. I'm sure it would've definitely helped, but I didn't have one at the time. I go back and forth between playing with the Vette and the Blazer, so I'm sure I'll get around to trying to fix the wrinkles at some point. I'm kind of thinking about going fairly outrageous with the Blazer in the near future, so maybe I'll just scrap them. I'm thinking about doing the whole custom dash and door panel thing anyway. And being that it's full convertible, there's more room to work in it. So, I'll be getting a little more practice in. Definitely keep me posted. I'm really curious to see how it comes out. I was going for stealth mode on mine, so I didn't really look into vinyl or paint, but you may change my mind...
#55
I am unable to do these types of things like I used to because of a serious work place injury. When I got the 81 a few years ago the speakers sounded like originals. I picked out some Pioneers the local Corvette dealer recommended as exact but modern replacements and a Pioneer 50 watt radio/cd. Sounds fine. They did an ok job in the rear.
