Hi folks, I pulled what I think is a pretty bonehead move yesterday. I'm installing a Petronix Igniter II in my 71. I'd put an Inginer in my old 65 Mustang about 10 years ago and it didn't require pulling the distributor (would've went that way again if I knew). Anyway, I knew it was important to mark the distributor location, but like an idiot I marked the housing and not the rotor. So, when I got it all back together, it was barely running. Something else I managed was to break my distributor cap, so I'm off to the parts store now.
I think the rotor is pretty close to where it was, but would like to find a link where someone walked through the process of installing and setting up a distributor. Can anyone think of one (Timing for Dummies maybe)?
Since the engine ran it's not too far off. Mark the housing right below terminal #1. Remove cap and rotate crank until rotor points to #1. Then set crank to about 10 degrees before TDC. The rotor should line up with the terminal mark.
You might be one tooth off. What you can do and I have done it is move the wires one terminal over on the cap. Try it one way and if it gets worse move them back to the original position then move them one terminal over the other way. Remember you can set up number one were ever you want as long as the engine and the distributor are together on the position. And just as long as the wires correspond to the rotor position.
Why do people on this Forum hang around just to rub salt in someone's "wounds" when he's honest enough to admit his mistake and then ask for help? Have you guys nothing better to do?
She's alive folks!!! The guy who rebuilt my engine had the distributor set up for the #1 cylinder differently than the normal" way. I'm back to stanardized now. Thanks for the help!!!
