What did you use?
Old Jul 29, 2012 | 06:53 AM
Street Rat's Avatar
Street Rat
Default What did you use?
I purchased a car with two leaking valve cover gaskets. Needless to say the under body is quite a mess. I tried some Gunk Engine Cleaner and a garden hose and it didn't touch it. The grease and grime is pretty thick in places. I want to be able to spray a product on liberally. Then I thought I'd power wash it. What products have you used that will cut through this mess?
Old Jul 29, 2012 | 07:19 AM
C3 4ME's Avatar
C3 4ME
Castrol Super Clean does a decent job. If it's that messy, I doubt you're gonna find a spray it on, hose it off cleaner that will get it completely clean. You're probably gonna have to get dirty on this one by scrubbing.
Old Jul 29, 2012 | 08:13 AM
ShootCraps's Avatar
ShootCraps
Safety goggles, face mask, putty knife and a wire brush. Get the thick stuff off then you can use the spray products.
Old Jul 29, 2012 | 08:18 AM
SIXFOOTER's Avatar
SIXFOOTER
Simple green works pretty well but most any of the engine degreasers will do ok, go ahead with the pressure washer, it will not hurt anything, just be careful around the wireing. Depending on the pressure washer you can blow off labels, cut insulation and that kind of thing. Don't worry about water in the distributor, you can dry it out. Take off the air cleaner for better access and put a towel and plastic bag over the carb with a rubber band and go to town on it
Old Jul 29, 2012 | 08:44 AM
AdamMeh's Avatar
AdamMeh
Best way to really detail it up and get rid of the grease.
Adam
Old Jul 29, 2012 | 11:38 AM
CQRT's Avatar
CQRT
Scrape first . . .then Simple Green and a wire brush . . then steel wool and more cleaner . . .I also used a power washer to get some of the old crud off the bottom of my `73 . .
Old Jul 29, 2012 | 11:50 AM
Jeff_Keryk's Avatar
Jeff_Keryk
In San Jose we have a place that does steam cleaning. They did "top and bottom" starting on a lift and then on level ground. Best $120 I have ever spent. As Six posted, be mindful of labels, etc.
Old Jul 29, 2012 | 03:22 PM
briankeery's Avatar
briankeery
If you have access to this, it's as trick as removing paint with dry ice. Our maintenance guys at work use this procees to clean all their presses......where you need a quality job in a short period of time.
Old Jul 29, 2012 | 08:09 PM
Street Rat's Avatar
Street Rat
I did a search for the steam cleaning procedure in the Austin area with no success. So it looks as though it's time to get dirty. I'll take all of your advice and do it right with the scrapers and such. Then I'll get out the degreaser and pressure washer. Thanks guys.
Old Jul 30, 2012 | 11:46 AM
chadronvette's Avatar
chadronvette
Veteran: Coast Guard
Super Clean from Wal-Mart proved to be pretty great at removing the grease from underneath my 72. Its dirt cheap but really workes well. Most parts I could just spray it on, wait about 5 minutes and hose off the grease. I did not expect it to work as well as it did, it is pretty caustic stuff but the label says its all biodegradeble.
Just my 2 cents.
Mike
Old Jul 30, 2012 | 06:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
How bad are those gaskets leaking, that they created such a mess??
I'd begin with a "milder" cleaner first, before "bringing out the Howitzers", by using a pressure washer. My suggestion would be as others mentioned, Simple Green or Castrol Clean, and use a stiff bristled "parts cleaning brush", that's available at most auto parts stores. Something else I've also used in the past, is laundry detergent or Dawn dishwashing liquid, again with a cleaning brush...
Old Jul 31, 2012 | 08:51 PM
kdf1986's Avatar
kdf1986
I used a combination of Simple Green and a generic brand oil/degreaser. Spray it on, let it sit, and clean with either a scotch brite pad or rags depending on the location.
For some spots I also used a spray such as WD 40 or some other petroleum lubricant then cleaned with a rag.
kdf
Old Jul 31, 2012 | 09:09 PM
harris1507's Avatar
harris1507
Zep industrial degreaser and cleaner from Home Depot, no scrubbing, I did my engine compartment when I took the engine out. I did power wash after it is super clean. You can get it in 5 gal or 1 gallon. you can make 25 gallons from the 1 gallon.
Old Aug 4, 2012 | 04:30 PM
Street Rat's Avatar
Street Rat
Default Update
Well I got out the power washer and the Castrol Super Clean this morning. Got all geared up in a suit, mask, gloves, and goggles and crawled under the beast. It was a pretty messy job but I got it done in about 45 minutes. There are still some grease deposits on the side of the transmission and on the rear end housing. That stuff is really on there good. I'm going to get the Zep industrial strength cleaner and go after those deposits again. For the most part it got pretty clean under there. Thanks for all of the advice my friends!
Old Aug 4, 2012 | 09:29 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Good to hear this. I need to clean my daily driver and this sounds like a good way to do it.
Old Aug 4, 2012 | 10:30 PM
junkman123's Avatar
junkman123
i put mine up on ramps,put on the face shield,got on my back with a short pressure washer wand and went to work,took care of every thing loose and dirty(paint,grease,dirt)
Old Aug 5, 2012 | 09:14 AM
69 Chevy's Avatar
69 Chevy
This 250 degree steam cleaner...works like magic on baked on grease/oil. http://www.northerntool.com/shop/too...1859_200321859
Old Aug 6, 2012 | 02:58 PM
lichtyr's Avatar
lichtyr
Cruising
Dawn Dishwash detergent and a sprayer mixed with water 80 /20 80 water let it wset clean as a whistle
To What did you use?
