Air Conditioning Control Panel
Old Dec 30, 2012 | 01:41 PM
Roma's Avatar
Roma
Default Air Conditioning Control Panel
I have a new issue
When I turn the wheels to set another position, the indicator does not move , both sides
Is there an easy trick to repair this or do I have to disassemble the panel ?
And if ... how ?
Thanks a lot in advance
Frank
Old Dec 30, 2012 | 02:03 PM
'75's Avatar
'75
Those are operated by strings that may be broken, needs to be removed for repair.
Old Dec 30, 2012 | 02:09 PM
7T1vette's Avatar
7T1vette
The 'drive strings' appear to be intact on both wheels. So, the possibilities of failure are: the indicators have come loose from those strings (possible but not so likely); the side-mounted cog wheel that engages with the [larger] drive wheel is not doing its job; or [most likely] the strings have stretched so that there is not enough tension on them to cause the indicator to move. Along with this last possibility, there could be some problem with the tension spring that this drive string is to pass over, such that no tension is being applied.
In any event, I think you need to disassemble the control head...at least to the point of finding and fixing the fault.
P.S. If you have to replace any of that string, you need to do so with a proper replacement. That string is tightly woven and is impregnated with wax (or some other water-resistant substance) so that it won't stretch with additional humidity. Regular string won't get the job done on this. Google is your "friend" for finding the right stuff.
Old Dec 30, 2012 | 02:31 PM
Roma's Avatar
Roma
Meanwhile I found this :
http://www.corvettemagazine.com/1968...panel-rebuild/
and the cause of my problem:
The indicator has 3 small pins that have somekind of wrapped with the string, but at both indicators 1 is broken
Do you think I can glue the string to the indicator ?
Old Dec 30, 2012 | 02:38 PM
7T1vette's Avatar
7T1vette
No. Well, I guess you could; but the indicator would no longer be self-adjusting.
The way it works is that the indicator is entertwined with that string...but not held in-place. When assembled, it is unnecessary to position that indicator. Anywhere you place it is OK.
Then, when fully assembled, the thumbwheels are turned slowly, BOTH ways to the extremes of their travel. When the indicators bump into the end of travel [at either end], the string will still slide through the tangs on the indicator..even if the wheel has not traveled to its extreme. Once the wheel does hit its 'stop', the indicator is then in its proper placement.
If you just glue it, you'd better be RIGHT!!
Old Dec 30, 2012 | 02:48 PM
Roma's Avatar
Roma
Maybe I glue somekind of bracket to hold the string to fullfill the correct operation ?
Im afraid of disassembling this thing
Old Dec 30, 2012 | 02:54 PM
7T1vette's Avatar
7T1vette
It is not that scary, if you are careful and take GOOD note of how it comes apart. Even if you want to attempt a rebuild of the indicators (they are relatively available and not expensive to replace), you would still have to disassemble some of that control head.
Old Feb 9, 2013 | 03:07 AM
Roma's Avatar
Roma
Does someone know if I can exchange the indicator needles without disassembly
the panel ?
Old Feb 9, 2013 | 08:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
One of the vendors has a rebuild kit for these (wheels, strings, small parts, etc). Find one and follow the directions.
Old Feb 9, 2013 | 10:26 AM
Roma's Avatar
Roma
Hi Mike,
I have bought an old one with good needles. The plan is just exchange the needles. Thats why I asked if someone has ever tried it without disassembling everything
Frank
Old Feb 9, 2013 | 12:13 PM
7T1vette's Avatar
7T1vette
You must remove the top plate and lenses to get to the indicators. I think [not positive...it's been several years since I was inside of one] that you can remove the (4) corner screws from underneath to get that top plate off.
Old Feb 10, 2013 | 08:09 AM
Roma's Avatar
Roma
I have tried to disassemble the old one .... no chance without destroying the plate. They are held together by deforming the plate and when you try to rebend it , it will break :
So I ended up in ordering this kit :
http://willcoxcorvette.com/product_i...oducts_id=6815
Hopefully it arrives soon
Old Feb 10, 2013 | 08:39 AM
7T1vette's Avatar
7T1vette
Well, that's an easy fix. I know that I've had mine apart before (cleaned the lenses, etc.); and it's back together now. I may have carefully bent [or broken off] only what was needed to get it apart, then locked it down in other places. If your's can't go together that way, there's always a bit of JB-Weld epoxy putty that can be placed in strategic spots to keep it together.
Old Mar 15, 2013 | 12:53 PM
Roma's Avatar
Roma
Today I was at customs picking up a box from Willcox
Now its working as it should
Old Jul 26, 2014 | 08:38 AM
Cairns-convert's Avatar
Cairns-convert
Default pulley replcement
Hi all,
I know this is an old post, just wondering if anyone knows of a suitable replacement for the small pulleys on the air conditioner controls that the string goes around at each end.
One of mine is MIA, didnt really want to purchase a whole rebuild kit for the one tiny pulley.
Any thoughts appreciated
Old Jul 26, 2014 | 10:13 AM
Corvettes by George's Avatar
0Corvettes by George
Former Vendor
Originally Posted by Cairns-convert
Hi all,
Send me a photo of the pulley you need---I have extras.
geopar@gvtc.com
Old Jul 26, 2014 | 11:58 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
All the heater control small parts are listed on our website. I also have detailed instructions on how to rebuild the control there too. If it is only one wheel.. I suggest you give sales a call on Monday. They can put this in a envelope and mail it to you way cheaper than what the website will calculate.
Corvette Heater Control Rebuild Suggestions 1968-1976
Heater Control Small Parts
http://willcoxcorvette.com/advanced_...ater%20control
Pulley
http://willcoxcorvette.com/product_i...ducts_id=25608
Old Jul 27, 2014 | 05:42 AM
Cairns-convert
Pulley
Cheers Willcox, I did check you site but must have searched on the wrong thing as I didn't see them listed individually. Am looking for "E" as listed on your image.
To Air Conditioning Control Panel
