How to fix aluminum valve cover
Old 12-30-2012, 05:49 PM
jschulz30
jschulz30's Avatar
Default How to fix aluminum valve cover
Any suggestions on how to fix the bolt hole?
Thank you
Jason
Old 12-30-2012, 06:33 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
How about a bit of TIG welding, and then some minor grinding, filing, and sanding?
I've done that on my aluminum valve covers.
Old 12-30-2012, 07:00 PM
jschulz30
jschulz30's Avatar
That would work, but I do not have access to a TIG welder or the ability to use one.
Old 12-30-2012, 08:51 PM
markids77
markids77's Avatar
Some MIG welders have an aluminum wire feed attachment... any welders in your neighborhood?
Old 12-30-2012, 09:45 PM
69427's Avatar
Any decent welding shop could add some material to that spot for a very small charge.
Old 12-30-2012, 09:57 PM
jschulz30
jschulz30's Avatar
Sounds like a plan, I will look into it. Thank you
Old 12-31-2012, 12:16 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
What's wrong with it, other than it has been 'dinged-up' with washers/etc in it's past lives? It doesn't look to be cracked.
If the underside of the cover rail (sealing surface) is smooth and flat, the only things you need for it to seal are a good gasket, the correct metal 'load-spreader' and screw/bolt, and proper bolt torque. If the problem is just cosmetic, use a Dremel and a fine burr tool or sanding disc to smooth up the roughness and put it back together.
I'd be more concerned about putting that much heat into an area that should not be distorted and must remain smooth and flat in order to seal.
Old 12-31-2012, 06:40 AM
Indiancreek
Support Corvetteforum!
Indiancreek's Avatar
Take your time with a dremel tool and dress it up. Otherwise I agree, Tig it up and dress it. I have a Tig but I'd probably dress it up with a dremel before I'd bother to Tig it.
Old 12-31-2012, 09:05 AM
jschulz30
jschulz30's Avatar
It is just cosmetic, all four holes are rough. Picked these up cheap just want them to look pretty.
Old 12-31-2012, 10:11 AM
luisv
luisv's Avatar
I would simply go with the rotary tool first. They to "smooth" out the gouges near the bolt holes so they are not so pronounced. Then the bolt heads themselves will cover a great deal. You can also go to studs for the valve cover which will be taller further hiding anything yo can't resolve.
Old 12-31-2012, 11:33 AM
C3-PO
C3-PO's Avatar
clean the cover really good. get some Devcon metallic epoxy (hi-heat). it shuold be good to 800-1200 degrees. it should seal okay. you can drill/machine it out.
To How to fix aluminum valve cover
Quick Reply: How to fix aluminum valve cover
