Clanking Noise in Rear
I hear a clanking sound when I pull out and make a right turn. If I go very slow no noise, but under normal acceleration I hear a series of clanks. Doesn't happen going straight, making a left hand turn, or at speed....just from a stop.
It is a 71 350 4-speed. I'm thinking a bad U-joint but there is no vibration or signs of a broken one.
I'm new to the SC area and don't have a trusted mechanic yet, so I am hoping to get some idea of what it could be so I don't end up doing a lot of uncalled for repairs.
Thanks.
Thanks.
That's what mine sounded like as is started to go. Had a new one installed and it broke within 6 months no warning or noises, replaced free on warranty by my mechanic.
Sounds are tough to diagnose on the Internet! What noise is it similar to?
I would think a bad u-joint would make noise all the time; anytime I hear "slow speed turn" I'm thinking differential, either posi clutches (usually not bad) or spider gears (expensive unless you can do it yourself). When you or your mechanic inspects the u-joints, get the rear tires off the ground and spin the wheels, listening for any noise from the diff gears. Pull the diff drain plug and make sure there is fluid up to or near the level of the hole. If the diff looks like the plug hasn't been removed in years, or if the fluid level is low, I would encourage you to pump out the old fluid and put in fresh gear oil and posi additive. If your u-joints pass inspection and new gear oil doesn't help, it's probably time to drop the diff and open it up...
Sounds like two pipes banging together. Rather loud but nothing to feel. This just started about 2 months ago but i dont drive it much. Have 90k miles on car. I checked u joints for play and they felt tight but that was with the car off the ground and the wheels hanging.
I will check the diff fluid level. Good idea.
