brakes
I've had the car about 3 months (really nice car)
Thanks, Jerry
Leaking fluid on the left side.
Stuck caliper piston on right side (not retracting and heating up the brake pads)
Bad hose on right side not allowing caliper to retract
Stuck caliper piston on the left side (not pressing the pads against the rotor)
If any of those has been going on for a lot of miles then you should see the pads more worn on one side than the other.
Andrew
800-442-0335
http://www.muskegonbrake.com
I upgraded to O-ring pistons (already had SS sleeved calipers) and no problems since.
Does it pull more when you get the brakes hot, the warmer my brakes got the more it pulled. Difference in pad Autozone/Advance .
It can be anything:
bad tire
bad shock
bad ball joints
bad tie rods (any of them, no matter front, rear, right or left)
broken spring
faulty piston in the brake calipers
oil on the brake shoe (any brake shoe)
glazed pads or overheated rotor(s)
bad or loose roll bars
broken frame, cross member, or even motor mount
to diagnose:
get the car up on a ramp if possible (the type used for alignments where the tires are still holding the car up)
look for leaks - antifreeze, oil, brake fluid, transmission fluid that is near a brake shoe
take a large pry bar and test every joint by prying on them - not huge effort, if something doesn't look right -it isn't
check the rear suspension as well because it literally could be any of them.
If those checks fail to bring up the issue:
check the body mounts and motor/transmission mounts
If those checks fail:
put the car up, off its wheels and check the bearings,
pay close attention to the trailing arm bushings
hopefully it's something simple, but if you methodically go through each suspension point, you should find it.
and the super benefit is; you'll know your car stem to stern so you'll see problems before the happen
