My new (ok, currently) least favorite C3 project!
Outter door handles....!
Arg.....that 7/16" nut in the upper corner.....!!!
Changed all four.....inner and outter....
Then....a fun and EASY project....painted my calipers....
Looks great,,, i have 2 new outer door handles i need to change, any tips or pointers. thanks.
what paint did you use on you calipers? they look great
I can NOT see doing this with the glass in the door...!!!!!!
Other than that, take your time....it's not rocket science.....
It kinda explains itself.....
1 Post
You really have to remove the glass and have lots and lots of patience. You will drop that damn bolt a million times before you get it started. I used a 1/4 ratchet with lots of extensions and swivel joints and that did not work. Ended up balancing the nut on the end of my finger and slowly started to thread it on. Once you get the nut started it is easy.
A "while you are at it" and while you have the window out, pull the tracks, clean them and grease them up with white lithium grease. If you are really looking to enjoy yourself in there where your hands don't fit and you cant see, pull your window regulator and clean and grease that. Pull your window motor out and grease the motor up also.
Enjoy!
Enjoy!
