Not the car...just bought '77 T-Top and previous owner was heavy smoker. Have tried every household cleaner, upholstery, vinyl and marine mold and mildew cleaner and nothing is working...thinking of acetone or lacquer thinner.
Is the problem that it stinks or you have stains? For the smell there are some ozone treatments that are supposed to work (you have to take the car to a shop, it's an expensive machine that does it).
If it is staining, clean well first and then spray a thin coat of interior dye on the panels.
Hotel's and motel's use a portable ozone machine ( oxinator...? ), to remove the cigarette smoke smell from rooms. Maybe you can rent or borrow one from someone close to you. Lou.
Cheap old trick that worked on my 75, also a former smokers car. Get 2 aluminum pie tins and a can of coffee. Put a pie tin full of coffee on each side floorboard. Stir twice daily for a week. Killed the tobacco smell in my car but it smelled like coffee for about a month. I could live with the coffee smell. No smell of any type left now.
Replace the carpeting and clean all the other surfaces with detergent/water. Or you can stick a Glade 'Hang-up' on the roof panel overhead. I don't think you can ever get the smoke smell out of the carpeting.
After my mother (heavy smoker) decided to quit smoking, I took her car to a local auto detailer who did the ozone treatment to her car. The procedure took 24 hours. When I picked up the car the next day I could not believe the difference. That was 10 years ago. She still owns the car - to this day no cigarette smoke smell.
A detail shop suggested I buy an ozone generator for a car I had with a mildew smell problem. Bought a cheap one on ebay for $60, closed up the windows and let in run for a long time. had to air it out for awhile later to clear the air in the car, but it worked extremely well.
I used a $10 fogger I got at Amazon, car running, AC on Hi recirculate for 30 minuets. That was 6 weeks ago, still smells like the fogger some but no cig smell.
Not any smell only the brown nicotine stains on on dash pieces...door panels, seat covers, and carpet have been replaced.
Great looking interior apart from the dash. I'd be inclined to pull the dash and re-dye. Even if you get the stains out it won't look as fresh as everything else.
I had a chest freezer full of fish and lobster accidentally get unplugged, and didn't notice it for a couple of weeks! After emptying it, and numerous goes with bleach water, it still smelled G-d awfull.
I used the above method of coffee beans (I used fresh ground), and I also added crushed newspaper that I lightly spritzed with water. It worked amazing, and I was able to save the freezer.
I was in New Orleans for Katrina and while I made it out my fridge didn't. Despite removing all interior panels and a bleach scrub the smell remained. I put a bowl of charcoal briquettes in there and when I moved back in a month later...... Presto! Smell that made me wanna vomit was gone.
