Chazde3's '68 Vette Project
#161
You are correct on that. Back in the day you could buy that brace from GM and a lot of us added it. I did that on my 65. You had to modify the fiberglass tub for clearance, so that is a dead giveaway for the upgrade.
#162
restore
Hey Chad, they added that brace in 69 and on. Check where the #3 rail meets the frame. That is a spot where a lot can happen with rust and lose of frame. Not telling you what to do just some tips..
R
As you can see on mine that it had to be repaired and took me a long time to fabricate just how to do it. I also added new gussets and cage nuts to the frame. Hopefully that will not be necessary. Good Luck!
R
#163
A poll on here recently found out that the extra brace was added in early April 1968, I think.
I also remember reading that GM would only make three runs a year for the Harrison expansion tank. My 68 has a 68 C, for March build date. Lou.
#164
You should find this helpful. http://www.71corvette.com/frames.html
Early 1965 - Indent added into the engine crossmember to clear larger pulleys
More specifically I believe that was for the big block engines.
#167
Well I haven't done much on the last week. I bought a work bench and put it into my office at home so I have a place to tear parts apart, clean and rebuild them.
Scott at Detroit Vintage Wheels finished my wheels a couple weeks ago. I haven't been able to get out there to pick them up yet due to plans or poor weather but I'm hoping to get out there tonight or tomorrow.
#168
Good to know
r
#169
Oh and it's Chuck btw
#170
I haven't been over to the garage yet since you asked. That's the bad part about being 25 min from your project, and I'm getting sick of the commute to work on the car lol. My tiny one car garage isn't suited to do much of anything in unfortunately. I will check on the date code this weekend.
r
#172
Picked up my American Racing Vectors that were remachined and powder coated by Scott at Detroit Vintage Wheels. They went from this:
To this!:
To this!:
#174
r
#175
Thanks r. His collection of wheels that he has remachined is amazing. Oh and I didn't get out to work on the vette today, but will be out there tomorrow and will grab that date code.
#176
Nam Labrat
Received 4,153 Likes
"New" Wheels!
#177
Hey rvizio, I'm slow. Got out to the garage after work to grab the expansion tank date code for you. Looks like it's 68G, looks like that is July of '68 which matches the car perfectly.
