***DIY:Headlight and tail light LED halos***
#241
I have no idea to be honest. I will probably leave the brightness alone as the LED brake light seems to shine through fine.
Unfortunately those are just as long of a wait as the ebay ones, lol. Having to wait over a month seems a little ridiculous for something that should be somewhat common. So since 90mm won't work, 80mm sounds like it should then. Then I could order something like these that will get here this week:
https://www.superbrightleds.com/more...it-board/1117/
Think mine took two weeks to arrive. I would just wait it out and get the one that you know you will be happy with. Just my $0.02
#242
I just got my 85mm ones in finally and...they don't fit, lol. In fact I have two separate batches and none of them fit. If I took off the cover, they might fit. This seems weird because everyone else's fit.
#243
The ORIGINAL and bestest
Toronto Events Coordinator
Have you measured the OD of the halos you have? I have some spare sets of the 85mm halos I used, I will dig them out and measure their OD tomorrow.
#244
I did take apart the license plate light where everyone wires it, are people just using one of those blue wire 'taps' and then putting the other four wires in the other side of the tap? Or are they completely cutting the wire and then tying them all together?
#245
With the cover they're like 87mm. I've figured out a work around though, I broke off part of the cover where it touched the screw holes in the housing and now it fits. I should be good to go now.
#246
Received 3,138 Likes
For what it's worth I had to relieve the plastic covers in the three areas where the screw were as well. A sanding drum on the dremel worked perfectly.
Being able to actually remove the pots is very important as 7t2 points out
I was already knee deep in the rear harness before this change so I went weatherpack and changed the bulb holders to center contact only style
M
M
#248
just standing on the shoulders of giants
M
#249
I just finished adding the LED halos to my tail lights and I love them!
The light on the left is an LED bulb that I already installed, so it is already significantly brighter than stock. I think I will try to add a spacer to the inner lights to separate the halo ring and the reverse light and get more definition.
Here it is all done
with the backup lights
with the brake lights
Here are the 80mm halos I used. ( )
and the bulbs I used ( ).
I had to remove the plastic cover to make it fit under the inner lenses, so I just removed them for all four. I don't expect the LED halos to last very long based on how much I paid for them, but now it will be fairly easy to put higher quality ones in when I need.
Thanks all who posted and helped, especially 7t2!
Here it is all done
#250
M
M
How do you get that inside part out like that? Are there nuts on the backside that allow it to come out? If I could remove that it would make this thing a lot easier.
#251
Those 2 studs you see in the picture go through the body and there are nuts on the inside, I believe one on each light also has the ground wire from the harness on it.
You can see one of the holes here, they are at like 5 and 11 o'clock
M
M
#252
For those of you who converted from two tail light + two reverse to 4 tail lights, how did you handle the housing? Like did you buy two of the housings for the tail lights to replace the reverse one? As it appears you need a different socket setup that doesn't appear to be available separately. I started to wire things up tonight when I realized that I should probably just convert to four brake lights, the halo going out the reverse lens just bleeds a little too much for my liking.
#253
For the simplest and easiest way check post 28 on this thread and I think Bruce shows how he adjusted the bulb to use the stock housings. (I think)
I took the 1157 socket out of the housing and replaced it with an 1156 socket from another old GM set of lights we had laying around.
M
M
#254
You could also just swap sockets in your housing like Mooser has done. A quick google search shows you can buy just the sockets from multiple sources, this is the first one I found: https://www.customled.com/products/a...bayonet-socket
#255
There you go, right answer right from the OP
The brake lenses do fit the reverse housings (at least on mine)
M
M
#256
Well I started removing the reverse housings tonight to modify with a different socket when the post snapped off from rust, lol. So I guess I'm replacing the housings. They kind of need it anyways.
#257
Ok, so I'm making some headway here. Got all the parts in for the most part to make the 4 brake light switch, the last part is I need a led strip reverse light for the license plate. I look on Amazon and the web and all I could see were 100's of random ones that all seemed to be of questionable quality, lol. Did someone here have some luck with one brand or another that they'd recommend? The best one on amazon seems ok but kind of like the halo rings, people were worried about durability on it and having short circuit issues. Thanks
#258
In case the earlier pics do not show up because of the photofuckit debacle:
taylor34 (03-26-2018)
#259
What I've found (like the LED bulbs I used) is these come and go and what is available today may not be next month so when I did my reverse light I found something that I could make work for me and then I bought several sets so down the road if / when they die I have one on the shelf. Especially when the housing was made to fit the strips I didn't want to have to start over again just because that supplier disappeared
M
M
7t2vette (03-26-2018)
#260
M
M
That is a very good point, and I have done the same by buying spares of the headlights, the front and rear halos, the rear turn/brake leds, and the strips I used for the reverse lights.
