***DIY:Headlight and tail light LED halos***
#261
I was doing some research for my project and I came across this thread linked from the "Cheap DIY Mods thread"
Then I saw it was originated in 2013, and I figured I was too late to the party... then I saw the most recent post was from today and the OP is still keeping at it.
7t2vette - You are the man. This forum is great because of people like you.
We are getting better customer service from you than I see from many vendors - and you aren't even profiting from this.
7t2vette (03-27-2018)
#262
The ORIGINAL and bestest
Toronto Events Coordinator
Since I am the originator of this thread, I see it as my duty to offer my assistance to anyone who needs it. I'm not in it for the glory or riches!!
#263
I'm getting close to wrapping this up (finally, lol) and one of the last things is what to do with the backup socket wiring after the conversion. I've got this black end (with contact at the end) that used to go to the backup light socket but is just hanging there now. Obviously I need to do something with that end, what did everyone else do? Cut it off? Wrap it up in black tape? Thanks!
#264
So I finally got my car going (brakes weren't working, had to tow it into the shop) and finally got to drive it last night. Does anyone else have radio interference when the lights are on? I turned on my lights and my radio station cut out, then I turned them back off and the radio came back. Tried it a couple more times and yep, it's killing the radio. Did anyone have to put a noise filter somewhere?
#265
#266
Btw, it's not necessarily electrical noise on the wire, but RF noise interfering with the antenna.
#267
I'm about 99% sure the problem is the halo rings. I've had this car for 6 years with not one interference issue, and the second I turn on the lights now (turning on the halo's) the radio signal cuts out, turn the lights off it comes right back. It's the only change I've made to the lights. Luckily I think I can verify this by temporarily pulling the power to them.
#268
I started this thread 5yrs ago, and myself and dozens of others have done this to our cars, and you are the first person to report this happening. I have 4 headlight halos and 4 tail light halos, and they have never caused any issues with anything else. I am sceptical that the led halos are causing any EMI or RFI issues, but I’ve been surprised by things before. Exactly what led halos did you use? I’m curious to find out if the problem goes away with just the halos disconnected.
#269
Received 3,219 Likes
And the only way to fix it- is replace the radio- as there are numerous threads on the web of EVERYTHING causing a problem with that radio.
Just do a Google search- "retrosound problem"
#270
If it is a "Retrosound" - yes, you could be having a problem with the LED's interfering.
I do have a retrosound
#272
Making a post in this now legendary thread.
anyone have a current source for a good headlight sized and taillight sized LED ring?
there's a heap of options and i don't necessarily trust em.
the brighter and more uniform the light, the better
headlight revolution seems to have a pair in many sizes, but at $120 a pair and $240 a set, that's yikes
https://headlightrevolution.com/diod...ck-halos-pair/
also, located an alternative to a reflector housing, these are inexpensive PROJECTOR housings, $90 for a set of four that come with some crap halogen bulbs you can toss immediately. No idea how easy it'd be to pry these apart to put in a halo
https://www.octanelighting.com/5-34-...w-clear-1.html
#273
This eBay listing for 85mm rings looks exactly like the ones I used:
https://www.ebay.ca/itm/2Pcs-85mm-LE...9dxQBp&vxp=mtr
This eBay listing for 125mm rings look very similar to the ones I used; the differences are that they have some sort of device in the wiring harness and they are 1mm smaller in diameter:
https://www.ebay.ca/itm/LED-Angel-Ey....c100008.m2219
#274
Trying to dig up sources for so called "HD" led halos, which use a coating of phosphor on the light scattering ring cover to remove the dashes between the individual LEDs of the rings, turning it into an unbroken ring of light.
the $120 diode dynamics ones do that but, well, $120
but i mean, lookit dat, pretty
panda motorworks has a set of four for $150 supposedly, https://www.pandamotorworks.com/prod...46a00884&_ss=r , a full $90 off a four set sounds good to me, although i question how legit this listing is
morimoto has good looking switchback 120mm halos as well, for $110 a pair, http://www.morimotohid.com/halos-pro...reselect=50180
although you can get the same ones for $90 from retrofit source so, there's that? https://www.theretrofitsource.com/ha...LOS?quantity=1
but reviews seem to be complaining that the morimotos have a more blue tint than their pictures let on, which is bad
it does seem like the industry, like many, has a huge gulf between really high quality american made stuff that's extremely spendy, and absolutely bottom of the barrel chinese stuff which won't last long
there's also a site which rates and ranks LED headlight bulbs, including putting them into reflector and projector housings and getting pics of their beam patterns which is an impressive level of detail
https://www.bulbfacts.com/led-kits/chart/
#275
Good luck finding LEDs made in USA.
I've played around with NeoPixels, from Adafruit. They are surprisingly bright, and would make great taillights if you are wiling to modify the housing a bit. You could have red brake lights, amber turn signals, and white reverse lights, all in one housing. They need an Arduino to control them, and 5 VDC input. The large ring is in 4 sections, and works out to 6.2" OD, so just a bit big for a headlight halo, but how cool would it be to have selectable colors, and programmable motion.
Anyway, you might find something that works for you. They come on ribbon cables, too.
https://www.adafruit.com/category/168
#276
It doesn’t look like the correct sizes of 126mm and 85mm are available from any of the above posted links, unless I missed it when I looked.
If these were available when I was first thinking about making these headlights, I probably would have just bought them instead. These look like very high quality units compared to all the eBay and similar junk being sold; they are pricey but as with most things in life, you get what you pay for:
https://www.dapperlighting.com/products/575
As far as I know, there are still no LED halo tail lights commercially being sold, so those would still have to be homemade.
#277
are 126/85 exactly what you need though?
it seems like, for the tail lights, 90mm would be too big as it'd impact the mounting holes but going a little smaller shouldn't negatively impact it?
same with the headlights, a little smaller shouldn't hurt
also, the dapper lighting set is all around great, but to get nice halos with good LED lights in a kit, the full set of four lights is over eight hundred bucks
if i do a little frankensteining i can do something very similar for less than half of that
https://www.pandamotorworks.com/prod...0884&_ss=r
of course i'd need to cut the buckets some and pop open the headlights to put the halos in, but that's it
https://www.amazon.com/dp/B077B3SNJR/?coliid=IR5XJ9KOCPVIB&colid=1HJYUT964UB7V&psc=1&ref_=lv_ov_lig_dp_it
https://www.octanelighting.com/5-34-...w-clear-1.htmlof course i'd need to cut the buckets some and pop open the headlights to put the halos in, but that's it
#278
126mm & 85mm are the largest you can go with the headlights I used and the 68-73 factory tail lights. Of course you could always go smaller with the halo rings.
I personally wanted the halo rings to be as big as possible:
Your results may vary.
#279
so, those octane bulbs are fake projectors, good thing i only got one
aside from those i cannot for the life of me find someone selling a projector housing in a 5.75 bulb aside from dapper's $359 option
so it's back to reflectors...
the octane reflectors seem to have no beam pattern, so that would be glare city
but it looks like Hella headlights have a very nice beam cutoff pattern. That combined with good LED bulbs which can be rotated to find just the right beam pattern, might get what i want
open question is, can those hella lamps be baked open? or do they use a "hard" adhesive that would have to be cut open?
of course the dark side option is get ebay special retrofit projector lenses, get some cheap clear lens 5.75s and throw the projector lens in there
#280
of course the dark side option is get ebay special retrofit projector lenses, get some cheap clear lens 5.75s and throw the projector lens in there.
I have no idea if the Hella units will be assembled with the same type of adhesive as the units I used. The Hella units will be high-quality 5.75" reflectors with correct beam patterns. To be honest, I've never even checked the beam pattern on the headlights I used for this conversion!
The problem with most projectors will be the overall depth, but I suppose if you don't mind cutting the headlight housings anything is possible.
A few years ago I bought a full set of Hella 90mm classic projector modules, but they are still sitting on a shelf! I was going to completely abandon the 5.75" units in favour of the 90mm units. Still might, don't know. If you do a google search you will see these modules being retro fitted into many cars.
These are the modules:
Hella has many different types of these universal 90mm units including bi-xenon and led units. Check their web site.
This is a link to the classic modules I have:
http://www.myhellalights.com/index.p...adlamp-module/
