***DIY:Headlight and tail light LED halos***
#42
I've been looking for a tail light set up like this for quite some time. Great job and excellent documentation!!
A question I do have, what about your reverse lights? I see you have the halos around your inner most lenses and an 1157 bulb wired for your brake. Did you just bypass the reverse hot lead and substitute a brake lead?
I'm contemplating adding the halo to my reverse lens and using the 1156 LED for a back up lamp and keeping the outer 2 lamps as brake / turn.
#45
I just finished doing this to mine. I installed red Angle Eyes inside my backup housings and kept the 1156s for the backup lamps. Since they are single-function, I chose to wire them in parallel with my brake/turn signals for maximum effect. They are a little different since the red around the backups are actually reflectors instead of lenses, but they still look really good.
I like the idea of keepint the backup lights too.
Ken
#48
The ORIGINAL and bestest
Toronto Events Coordinator
I am using a regular type of flasher, just the electronic version. It works fine as long as I keep regular incandescent lamps in my front & rear side marker lights and front indicator lights. When I put LEDs in the front indicator lights, the flasher doesn't work properly. I am currently working on a really cool LED swap for the front indicator lights, and I will have to address the flasher issue at some point.
#51
St. Jude Donor '13
I've had similar issues when changing my front T'S to LED. They are really dim and don't work too well. I did put LED in all my corner marker lights and it looks pimp! Red LeDs in rear and yellows up front.
Any idea on how to remove speedo & tach? I replaced my center gauge bezel lights to LED. Awesome!
#52
Been there, done that, when I did the body-off restoration to the car. If I ever have to go back there again for any reason, I might consider swapping them then....but, are they actually any brighter than the regular lamps?
#53
St. Jude Donor '13
Yes. They appear light blue in comparison to the yellow filament style. So far I have the center gauge bezel lights swapped and the speedo w/ green for L signal indicator & blue for high beam.
Just picked up my new flasher today. I'll put it in once it gets above 40 outside.
#54
Okay, I finally got a few pics together. So as not to muddy up 7t2vette's thread, I started a new thread.
#56
LED Halo and Sylvania Headlights
7T2Vette:
Great detailed write up. I'm going to do your exact mods on my "65 StingRay. I especially like the way did the front lights - very impressive.
And your advice about the relay's from Mad Electrical was right on. I bought his relays last year. So now I will be able to put in the Sylvania headlights with the LED Halo.
In the rear, like you said my tail light lenses may be too small for a halo but I will attempt it anyway.
Thanks again,
Wayne
65-StingRay
Thanks again,
Wayne
65-StingRay
#57
Halo headlights with Sylvania lamps
7t2vette;Bruce,
65-StingRay here. I don't know if you have seen my last message in your headlight thread. Anyway I really like how you did your halo headlights.
So if you you don't mind I'd like to copy them.
I've ordered almost all the same parts including the headlights you used but the hurdle I am up against is - what part number did you use for your Sylvania head lamps (bulbs). I know you mentioned H4 and H1. Did you use the newer zXe lamps. What I also need to know - did you have to make a pigtail adapter with 2 varying connectors to connect the headlight plug with the lamp prongs or was it a simple plug and play. I've looked at a few of the lamps on the net but they don't look like they would work.
Maybe while my brain is still in gear you could tell me how long it took to heat and separate the glass from the back casing so you could glue in the led halo.
Bruce, thanks in advance for any help.
I know I e-mailed you personally and you can return to me in kind but if just post the answer to my questions in your headlight thread that may be better for others as well.
654-StingRay
Wayne
654-StingRay
Wayne
#59
7t2vette;Bruce,
654-StingRay
Wayne
654-StingRay
Wayne
I used the Sylvania Silverstar zXe H4 lamps for the low beams, and they plug right into the stock harness plug. Here is a pic of the H4 lamp:
I used regular (non zXe) Sylvania Silverstar H1 lamps for the high beams, and I simply plugged the male spade ends into the harness plug. I can't remember if I made the adaptor leads, or if they came with the headlight. Here is a pic of the H1 lamp adaptor leads:
As for the time heating the headlight to remove the glass, it doesn't take very long. I used a heat gun, moving it around the headlight for awhile, then trying to pry it apart gently. Just did it several times until it came apart easily. Use gentle pressure, and use a plastic tool!! After it was apart, I continued to use the heat gun to heat up the remaining adhesive on both the reflector and lens to soften it so I could remove it all.
Resist the temptation to use anything made of metal for any part of this! It is so easy to break the glass lens, and/or scratch the metal reflector!
Post some pics when you are done!
