Spray Rubber Removal Help
Old Apr 4, 2013 | 01:06 PM
EngineerJay's Avatar
EngineerJay
Default Spray Rubber Removal Help
The previous owner of my 1971 was a little over zealous with spray on rubber and as such, several things I am trying to fix are hidden under a coat of rubber. Anyone have any good methods for removing it? I am currently concerned with the wiper area, but there is a little on the interior under the dash pads.
Any help is appreciated!
Thanks,
Jay
Old Apr 4, 2013 | 04:24 PM
Mooser's Avatar
Mooser
Saturate a rag in Varsol, hold it on and let it soak, that should loosen/ dissolve the most rubberized undercoat (especially asphalt based)
HIH
Mooser
Old Apr 4, 2013 | 04:40 PM
Alan 71's Avatar
Alan 71
Hi EJ,
I've used lacquer thinner with success too. Just be sure you have some fresh air since it can make you a bit woozy otherwise.
My wife insists I never recovered from using it.
Regards,
Alan
Old Apr 5, 2013 | 11:52 AM
Mashman's Avatar
Mashman
Also, the most likely reason it's there in the first place is because a OP was trying (succeeded?) to stop a water leak.
Over the years the sealant in the wiper bay stops working, and you get water leaking into the cockpit. After you remove the undercoating, you might want to look at making sure the area is sealed up, and not leaking like a sieve.
To Spray Rubber Removal Help
