Doorgunner's '68 Convertible Project
#2001
Nam Labrat
Received 4,173 Likes
Ok, send DUB a PM and ask him the best cloth and resin for fabbing new bond strips. ok, the nose. how are you doing the side pieces? cutting them out of the fenders and bonding the lip in it's place? or grinding the lip down till it is the right thickness and attaching it to the existing fender? i think the second way will be much easier. first way a touch more authentic, but it'll be mostly hidden under the bumper anyway. do you want the whole thing in 1 piece? or the front section and the 2 sides? and the grille openings on the side. attached to the bumper lip or separate? and BTW: POST NUMBER 2000!!
I've been at the hospital all day until 9 pm with my father-in-law.....so the car didn't get touched/I wasn't able to buy the adhesives, fillers, cloth, etc.
I like your idea of the second way. However you think the parts should be is OK with me/it doesn't matter if it's one piece or three pieces.......What ever is easiest to put in a cardboard box.
#2002
Nam Labrat
Since I know NOTHING about fiberglass work I spent the last two days reading thru all the threads in the PAINT/BODY sub-forum on the subject of fiberglass repair.
Now I have three headaches
According to the info, it also looks as though I will need an entire day to remove all the "1/2" thick stuff" that was used by the P.O's body shop to bond the '76 tail light clip to the deck/quarterpanels.
Oh well................................prac tice/practice/......etc.
#2003
Can't just line everything up close and make it work?
Pics in post 1969,73 and 79 look good enough to me, but I'm no expert by any means, just trying to save some humpwork.
rcsbls2 (07-03-2021)
#2004
The alignment is good. We are just trying to get the back side correct so when tony sticks the stuff on, it stays...
#2005
And on the other end of the car...these are the first pieces pulled from the mold. I have some flaws i am gonna try to fill. Also gonna try with cloth for first layer to see if it'll sit deeper in the mold.
#2006
Nam Labrat
ALMOST! NORMALLY......that would be the plan.
On the tail light clip I have everything very close and flush.....about 15 more minutes of trimming should do it........
HOWEVER................................. ..............
The problem I found is that a body shop "smeared" adhesive and cloth 1/2" thick and 6 inches wide across the underside of the deck and quarter panels where they met the '76 tail light clip in order to bond it to the deck.......it is 3/8" TOO thick for the new bonding strip to lay flat against the underside of the deck......you can see the thickness in the pic (remember when I thought that I had cut the bonding flange aloose....it was actually "gobs of adhesive mixed with fiberglass mat"
Also.....when I wedged a gasket-scraping tool under the edges of the "bonding strip" described above.....I can pop the "bonding strip" aloose in several places.
ALL of that "junk" has to be removed so a real bonding strip can be glued to the underside of the deck and quarter panels.
NOW......about the 1970 donor tail light clip.....it is completely original....no "junk" adhesive has been added to the underside of it. It is about 5/32" thick----an original body part.
I will prep it for bonding first today since it will be the easiest piece to deal with.....and to gain some experience with cleaning/ bonding.
#2007
Try a heat gun. That is how they seperate panels. Especially since you can heat the goop side instead of the good side. Slip a wood chisel between and heat the goop.
doorgunner (10-08-2015)
#2008
Nam Labrat
#2009
Nam Labrat
RATS!
More delays......maybe tonight I can get to the garage!
#2010
What song was that line from? "Life gets in the way."
#2011
Nam Labrat
#2012
doorgunner (10-09-2015)
#2013
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
The following 2 users liked this post by Jud Chapin:
doorgunner (10-09-2015),
Pegan2261 (07-11-2021)
#2014
Tony, I hope everything goes ok. A bunch of us are pulling for you...
#2018
68 vette
All of the above Tony. Prayers are with you and your family.
R
R
#2019
Nam Labrat
Thanks Men! He's 88 years old....so even anesthesia is a challenge for him......surgery starts in 15 minutes....doctor doesn't know how long/1 hour to 3 hours depending on the number of blockages in his legs and if they can control the situation during surgery.
Excerpt from page 1 of this thread:
Doorgunner's '68 Project; NOTE: When I started this thread, I had no idea of what life had in store...so this is turning into more than a build-thread.
