Doorgunner's '68 Convertible Project
#2841
Nam Labrat
Received 4,176 Likes
They gave me some good stuff to "smear on it".
Thanks.....the PTSD has temp. let up/I'm trying to get the car paintable while I feel good enough.
#2842
My cousin has had an agent orange related leukemia, but he has been lucky, his body reacts opposite to any case his doctors have ever seen.
He is currently a case study and the doctors are writing a book based on his treatment, hopefully their findings may help in a cure for others.
#2843
Nam Labrat
grateful rookie.
#2844
Nam Labrat
"Funny Story" :(smilie toe tap):
Speaking of Veteran's care/"Funny story": There are signs at the Clinic on every wall stating "If you have not been consulted within 20 minutes of your appointment please notify someone".
Not being one to bother other people,I waited an hour past my appointment to ask someone what the problem was. The Employee took my name and.....................15 minutes later returned to inform me that the DOCTOR had ALREADY seen me!
Now.....I'll be the first to admit that I have BAAD DAYS.....but.....NOT THAT BAAD!
I then informed the DOCTOR that I WAS ME/produced MY I.D.,and she said TO ME...................................... ........................................ .................
........................(wait forrrrrrrrrrr it)..................................... ........
"THEN------WHO DID I SEE????????????"
Ya' just can't make this stuff up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and we wonder why we're $18,000,000,000,000 in debt
#2845
And the real bummer...He got your meds!!!
#2846
Nam Labrat
#2848
Nam Labrat
LOL!
O.K. I'm calm now.....reason being................................
these babies arrived an hour ago.....................
Hopefully I will be able to start repairing the #4 mounts per Dub and bolt the body down onto the frame/chassis tomorrow!
#2849
Glad to see that you got them...NOW...getting them is is another story entirely.
You have got this covered...I have no worries.
If you have issues/problems.....let us know.
DUB
DUB
#2850
heck, just punch a hole thru the wood and run in a bolt!!!
#2851
Nam Labrat
EDIT: I was using "gusset" the wrong way.....I meant "fiberglass support" that the gusset fits in the bottom of.
Derek.....you know me...that would be wayyyyyyyyyyyy too easy!!!
#2853
glad to have you back with us. i sold my 75 coupe so i can start doing MY chrome conversion on the 75 vert in the forseeable future. right now i am trying to get a couple of 454's together and into my two project boats sitting in the yard...
#2854
Nam Labrat
Those front fiberglass "nose" pieces you sent me will get put on soon.
#2855
Nam Labrat
MORE BODY MOUNT REPAIR
It'sa good thing DUB talked me into doing the repair the right way....I found a nasty vertical crack inside the body support that needs repairing also.
I had to remove the driver-side hinge assembly and drill out rivets....
I taped the insideof the metal re-enforcement toprevent the fiberglass from sticking to it/then thoroughly sanded the area inside the mount.......then I pressed the re-enforcement into place under the body...................
Good thing I waited for the metal re-enforcements as DUB said.....I NEVER would have discovered the crack in the left-rear inside corner and never would have formed the inside fiberglass radius' correctly!
I will use a few small screws to hold the metal re-enforcement in place.
I made this per DUB so the repair will have a smooth flat bottom for the bolt and thick washer to seat against.................
#2856
Nam Labrat
After applying 5 layers of fiberglass cloth and resin and letting it cure for three hours I added a nice coat of satin black to hide al my sloppiness.......(I should have let it cure overnight before painting, but it should cure from the bottom up since I didn't paint that area.................................... ..
Next I need to bead-blast all the inside metal parts and repaint them before I rivet and bolt everything back into place..........
#2857
Glad to have been some help. Seems like this area is STOUT as it should be...once again.
DUB
DUB
#2858
Nam Labrat
I'll do the same to the passenger #4 mount tomorrow (hopefully).
So, DUB.....thanks again!
#2860
Nam Labrat
It took 3 hours from start to finish on the disassembly, body support prep, fitting the metal re-enforcement correctly, and fiberglassing the area.
I still have a couple hours of blasting metal pieces and re-painting them...installation will take only about an hour to rivet and bolt in the painted parts.
