Doorgunner's '68 Convertible Project
#4581
Nam Labrat
Received 4,173 Likes
DG
I stripped that area by hand and the radius on mine was minimal, to the points it's a sharp edge...so to speak.
And....the angle from the top edge down is different all around the opening. I was very careful when sanding to stay away from that edge to maintain the edge.
Thanks everyone for the great help and advice. Derek...I'm not getting the complete clip/just the flat part that surrounds the headlights since mine is covered with bondo and cracked off. Thanks for the pics Norm and RR.....now I see what I need to do.
I'm going to the garage between rainstorms to study the situation.
#4582
That would probably ship in 2 end-to-end boxes like I did with the bumper lip. 40-50 bucks FedEx or UPS ground.
#4583
Nam Labrat
I spent a couple more hours on the deck channel sanding the added fiberglass to prepare for body filler. I also decided to seal the rectangular drain holes so leaks in the rectangular deck support/drain would not leak because of hidden stress cracks or the large hole in it on the driver's side. Per Derek I placed aluminum sheet metal tabs in the holes to support the fiberglass filler.........
Now....back to the garage to apply body filler across the rear channel.
#4584
Nam Labrat
More channel work/nearly finished (or close enough for the paint shop).
I sanded the body filler to a sharp edge across the back of the channel....Then turned the sander on it's edge and sanded the filler on the channel shoulder................................ ...
I used a 2 1/2" dia. sanding wheel to cut the corner radius' into the channel..................
Since I extended the cargo area all the way to the rear frame crossmember I filled in the vents with fiberglass earlier....today I leveled the inside of the sealed vents with body filler. I will install 1/2" aluminum tubing so the rainwater can drain completely (using lowbucks method)...........
That's it for today.
#4585
Vette
Nice tools DG, they come in very handy for certain types of work. Your getting pretty good at all this dude!
RVZIO
RVZIO
#4586
Nam Labrat
So far I'm finding only surface voids/divots. I accidentally dripped filler onto the drain groove in the channel (too tired) and thought I'd just pop it out with a screwdriver.....not so....
I had to use a small chisel and hammer to break it loose/then sand the remainder flush
It's good to know the filler adds strength to the repair as well.
(Sleep 3 hours/awake 3 hours/repeat )
#4587
Nice job on that radius, btw!
#4588
Nam Labrat
Thanks oldgto......................yes, I have to fit the chrome vent grills...the gas door will be usable but I have to seal around the filler pipe so gas won't drip into the extended cargo/trunk space....also have to reroute filler pipe-to tank between rear wall of trunk and tail light panel.
#4589
Nam Labrat
Since I couldn't sleep last night I decided to update the 1st page of the thread to make it easier for me and members to locate certain parts of the Project.....Whew!
NOTE: When I started this thread, I had no idea of what life had in store...so this is turning into more than a build-thread.
I'm new to Corvettes and want to buy a very neglected '68 convertible near my home with late '70s front & rear bumpers....
Side note: I've had the "fever" since 1968 when I saw that $4,550 red Corvette on the showroom floor at the local dealership.....and ended up with the $2,695 1969 Camaro convertible that was sitting next to the Corvette!
I'm not trying to "restore" to a factoy look since the car is a "basket-case" vehicle......I have no bodywork experience.....just want to get the body back to 1968-looks....and have a D.D./keeper just for me.....
Thanks for any input/threads-to-read...since I'm learning as I go....
Some of the experimental mods that I try on this car would NEVER EVER be tried by me on an original car!
Build Date Dec 14, 1967
Time for a TABLE OF CONTENTS!
Advice/Finding the "Right Car".................................... ......pg. 1-2
Bringing "her" home.................................... ..................pg. 3
Removing interior & Re-insulating/soundproofing..............pg. 4-5
CAI (kinda')/Seat covers/Alternator mods.........................pg. 6
Temporary Exhausts/Seat covers/Salvage yard Vette.........pg. 7
More CAI/Cooling fan mods/Brake rebuild.........................pg. 8
Brakes/Differential/Trailing Arm Rebuild............................pg. 9-10
M. Cylinder/Distribution Valve/Re-center Differential Prob...pg. 11
4 Wheel Alignment and Problems................................ .....pg. 12-14
Suspension Alignment/Springs/Shocks/ChitChat................pg. 15-17
"Straightening Bubba's" Trailing Arms/Interior Carpet........pg. 18
Oil Pan Leak/More Suspension Repairs/Damper repair........pg. 19-20
Exhaust Wrap/Infra-red-Gun readings..............................pg . 21-22
Seat Covers/OilPan Gasket/Seat Covers............................pg. 23-25
Cooling system cleaning/RANT!/Gatlinburg Trip..................pg. 26-27
Sandbagging warped hood/Idle Chit Chat..........................pg. 28-29
Engine Overheating/Son and Depression/Seat Belts............pg. 30-32
Exhaust Mods/Softtop S. Carolina Trip/Top Rebuild..............pg. 49-52
Softtop Rebuild................................. ..............................pg. 53-57
Steering Column Rebuild................................. .................pg. 60-62
Allergy Treatment aarg/Broken Door Locks.........................pg. 63-64
Car Alarms/Parachutes/Projects................................ .........pg. 65-67
Rebuilding Door Mechanisms/Door Lock Rebuild...................pg. 68-69
Door Panels/Car Show/Speedometer Gears/ChitChat.............pg. 70-71
Passenger Door Panel-Again/Veteran's Discussion..................pg. 72
Calo69 Car Show Pics (lots of Vettes/etc.).............................pg.73
PTSD/Rant/Encouraging Members/Back on Track....................pg.74-76
SOLD '34 Truck/New grills/engine harness...P/B conversion......pg.76-77
P/B conversion/TH400 Re-wired................................... ..........pg. 78
Speedometer glitch-repair/cooling fan delay-relay(s) upgraded...pg. 79
New CAI Plenum/New-larger steering wheel.............................pg. 79
CAI and sidepipes............................... ..................................pg. 80
Steering wheel/sidepipe install/CAI..................................... ....pg. 81-83
Distributor problems........AGAIN................... .........................pg. 84
Distributor electric parts rebuild................................. .............pg.85
Rebuilt distributor installation/timing.................................. ...pg. 86-87
Upgrade to electric fuel pump.................................... ............pg. 87
Chrome FRONT Bumper Conversion/Click here for the condensed shortcut: https://www.corvetteforum.com/forums...post1590451458 ...pg. 88-93
Conversion Discussions/Cutting Fiberglass Grill Off.............pg. 93-95
Two Year Review of the Build................................... ........pg. 96
Chrome REAR Bumper Conversion/Click here for the condensed shortcut: https://www.corvetteforum.com/forums...post1590630203.......pg.97
More useful advice about fiberglass replacement..................pg.98-104
Motorcycle Discussions (while waiting for parts to be delivered)...pg. 105-106
Enlarging Cargo/Trunk.......pg.107-109
(click here for condensed Shortcut): https://www.corvetteforum.com/forums...post1590742891
More Chrome Front Bumper Modifications........................... ...... pg. 110-111
Fuel Tank Custom Modification/Click here for condensed Shortcut...........https://www.corvetteforum.com/forums...post1590803576 ...pg. 112-116
Tail light Clip Conversion.............................. ......................pg. 116-118
PTSD Chit Chat.................................... .......................................p g. 118-127
More Tail light Clip Conversion.............................. ........................pg. 128-130
More Enlarging Cargo/Trunk Area.................................... ..............pg. 131-135
More Tail Light Clip Conversion.............................. .......................pg. 136-137
Deck Lid Restoration............................. ........................................ pg. 137-139
Body Lift/Body Mounts & Reinforcement Repair/Replacing Front Crossmember and Braces........pg. 140-145
(for shortcut clik on the link to the right): https://www.corvetteforum.com/forums...post1591645717
Humorous Story About Visit to V.A. Hospital..............(Click on quick-link https://www.corvetteforum.com/forums...post1591683265) ......................pg. 143
Fabricate Support for oversize Radiator...............................p g. 146
Driver-side Fender Support Repair.................................. ....pg. 147
Test-Fitting Front and Rear Bumpers................................. ...pg. 149
Shimming Body Mounts for Door Gaps.................................pg. 150
Family Illness................................. .................................pg. 151
Family Tragedy................................. ...............................pg. 153-157
Emergency Sale of our house/packing to move away............pg. 158-160
More Tragedy................................. .................................pg. 161-162
Great Flood of 2016.................................... .....................pg. 163
Moving to In-law's during the Flood................................... .pg. 168-169
Trip to New Orleans and to Car Show..................................pg . 170-171
Fuel tank testing and fitting under car.................................pg.1 72-174
Support for Tank fabbing and fitting................................. ...pg. 175
Replacing rotted rear Cross member.................................. ..pg.176-177
More tank fitting with new crossmember............................. ..pg. 178-179
In-laws are united in Heaven.................................. .............pg.180
Moving to new home/new garage for Vette............................pg. 181
Moving Vette to new home/New garage & boxes....................pg.182-184
Repairing Rag-joint/Chit-Chat/New Sand Blasting Cabinet........pg. 185-186
Moving equipment into new garage/re-installing side pipes......pg. 187-188
Garage A.C./Insulation/new pegboard walls...........................pg. 189-190
Roadtrip (less Vette) to California.............................. ...........pg. 190-191
Hoist for hardtop added to garage.................................. .......pg. 192
Loading pegboard walls with Car/motorcycle parts...................pg. 193-194
Studying front Clip/work on Tail Clip/Repair cracked door jamb..pg. 195-196
Bonding exhaust panel to body/Fitting rear chrome bumpers.....pg. 196-199
4 year Review of work done so far..................................... .....pg. 200
Forum Chit-Chat with friends................................. .................pg. 201-203
Lowering garage onto slab after removing sub-floor...................pg.203-204
Painting garage floor/Bolting garage to slab..............................pg. 204-206
My Son's Memorial Day/Me learning to use a Wheelchair!............pg. 207
Forum Chit-Chat about Life.................................... ..................pg. 207-208
Repairing rubber fuel lines in engine bay...................................pg . 208-209
Forum Chit-Chat/Learning to use wheelchair in garage................pg. 209-210
Snow Storm of 2017/Forum Chit-Chat/Christmas 2017................pg. 211-216
Can't walk/Spine Surgery/Recovery/Chit-Chat............................pg. 214-216
First day on project since Surgery................................. ............pg. 216
Exhaust panel fitting/Finishing with body filler.............................pg.21 6-220
Door Gaps/Exhaust panel/Door Gaps.................................... ......pg.220-222
Garage Addition/Forum Chit-Chat/Garage addition/Door Gaps.......pg. 222-227
Repairing Channel that deck lid fits into.................................... ..pg.227-230
(to be continued.......if God says the same!)
Well.....that took only 3 hours!
#4590
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
Great job on the index DG
#4591
Nam Labrat
Thanks RR......I was taking the day off but I needed to see why the bolts wouldn't hold the hinges for the deck lid in place even after I ran a tap through the nuts. The rivet nuts were rust so much that they were spinning inside the deck support channel.
I wasn't about to remove the support to replace two rivet nuts so BUBBA told me to drill through the support channel and install 2 thru-bolts to hold the upper hinge in place.....I listened.......
The other hinge nuts are worse
suprkoop (03-21-2018)
#4592
Keep up the great work.
#4593
Nam Labrat
Thanks OCB!
Today's challenge was to replace the twisted-off rivet nuts on the driver-side deck hinge with something stronger. I used I/4" x 1" x 6" long steel flatbar drilled and tap and drilled for pop rivets to hold it in place once it is bolted together. I also tapered the bolt threads to help locate the blind holes they fit in...........................
It isn't positioned yet......(notice the hole that the seized rivet nuts made when I tried to remove the retaining bolts).......the pop rivet you see is installed in the plate-only so I can hold it to move the plate into position/it also prevents the plate from falling out of sight into the end of the support-channel.............................
The insert has been positioned and the two upper bolts have been tightened.............................
The lower bolt is tightened............................... .........
Deck lid bolt hole measurement across.................................. .........
Bolt hole measurement across from hinge to hinge........................
That's it for the A.M. I pulled (ouch) a back muscle. Tomorrow I will install the two pop rivets to hold the threaded bar in place....then I will fiberglass over the large hole.
#4594
Nam Labrat
More deck lid work this afternoon. I sanded down the filler I added around the edges of the deck lid. There are some areas that need building up/out more.
Passenger-side top of quarterpanel............................ ..
Passenger-side corner radius..................................
Driver-side corner radius.................................. ..
Driver-side top at quarterpanel............................ .......
Plenty of trimming needs to be done so the deck lid will fit into the channel.
#4595
Nam Labrat
Ahaaaa! This channel shoulder should be vertical per the blue car example picture.........................
#4597
Before gassing the hinge mount in, be sure you have it either in place correctly or within range of any adjustment ability. WAAAAY over 99% you have this covered, but other people are gonna use this as a guide to do this repair...
#4598
Nam Labrat
Thanks Ragtop!
Thanks Derek.....with my meds I need you guys to double-check me just in case I (usually) forget something. I measured the hinges hole-to-hole just to be sure.....within 1/8" of the deck lid mounting holes....plus.....each hinge has 1/8" of sideplay to make up the difference.......
Out to the garage with my new straightedge to tweak the inside shoulders of the channel.
#4599
Thanks Ragtop!
At this pace your gonna run off and leave me in your dust !
#4600
Nam Labrat
I spent about 6 hours fighting......errrr.....having a fit......errrr fitting the deck lid in to the channel. So much for "trim the edges of the deck lid to be square" and then bolt the lid in place!
The hinges were straight within 1/8" overall but when the lid was installed the lid sat crooked. I spent 2 hours readjusting the hinge bolts just to be able to rough-in the edges of the lid that I built-out.
I did chip a couple spots on the deck lid edges since it was too wide to fit in the channel on the first try. After 2 more hours of sanding away some of the edges/body filler I was finally able to NEARLY close the lid.
Another two hours of sanding off more of the body filler I was finally able to close the lid completely.
I used a mini level to sand the channel shoulders square.........
The left side is sanded square and the deck edge sanded away until it fit in the channel..........................
I did the same procedure to the passenger-side until it fit in the channel..............
The passenger door gap/lid gap/quartepanel gap are ready to be filled so they are all flush with each other....................
Front and rear pics of the deck lid roughed to size/it opens and closes with no problem................................
The deck lid probably was permanently bonded closed 30 years ago by the previous owner when he converted the '68 nose/bumper and tail light clip to '76 rubber bumpers front and rear
Tomorrow I will repair the chips on the deck lid edges and also fill in gaps where needed.
I now see that it would have been better to build-out the edges of the deck lid with fiberglass rather than use body filler to avoid chips while handling it for hours.
