Transmission cooler lines route?
I can't tell from my pictures but do the two transmission cooler lines on my '79 project go between the lower A arm and the frame or just route under the frame to the Rad.?
Received 3,139 Likes
They may have changed things but mine went above the lower a-arm. Had to pass it through when I changed them.
M
M
You can purchase premade lines and install them unless you really want to bend them yourself. From 1977 through 1980 here they are
http://www.ecklerscorvette.com/catal...smission+lines
