Happened Upon This Vette
https://www.corvetteforum.com/c3-gen...post1583096314
https://www.corvetteforum.com/c3-gen...irections.html
Big SAFETY TIP here. Keep your hands and arms out of the steering wheel BEFORE you start the car, because the steering wheel may move suddenly and violently, depending on the control valve is set. Just reach around the steering wheel to start it, and you'll be OK. After the first initial movement, it should settle down and be still.
The control valve adjustment is really a 'centering' act between left and right. With no input, it shouldn't move at all. If it does, it's because it's biased in one direction or another. By manually pushing on the rod in either direction, with no input you should feel the same amount of force going in either direction.
When you're happy with that, shut the car off, attach the ram to the frame and then start it up again (same precautions) and see if the steering wheel stays still and then, if you can feel the same amount of force going either way. If you can, put on the wheels, try that out and if it feels ok, drop the car and take it out.
Anybody else, please feel free to chime in, if I left something out!
Have somebody wiggle the steering wheel while you look for where the play is.
I messed with mine so long I finally put a rack and pinion kit in it. Tight as a drum now. I love it.
Where in ontario? Some locals might be able to help out.
dodosmike
Now drives like new and probably good for another 34 years.
dodosmike
There are so many places a Corvette can have slop in the front steering and front and rear suspension. You just need to check everything piece by piece. Any original rubber front or rear will be bad just from age. Lower ball joints never lasted long, I'm sure they are due. The idler arm is usually loose by 40 to 50 thousand miles.
It sounds like a disaster, but if you get good rebuild kits from someone like Wilcox during a sale, it eases the pain and you will get quality parts. They aren't really that hard to rebuild, just time consuming and a lot of elbow grease. The rear can be tough if the trailing arm bolts are frozen, still doable in your own garage.
One problem you may have after replacing worn parts is most alignment shops have no clue how to properly align these cars. Do not use stock specs here either. Search for alignment and you should find specs from one or more of the distributors that will work better for handling on modern radial tires.
It's well worth fixing it right. It can make the difference from loving the car or growing to hate it.
