Rant of Aftermarket (vinatge air)
gdh, sorry to confuse you. JasonB86 is correct, the end results to me, were far greater than the installation time. I chased gremlins on my original 76 factory a/c for two years and this ended up being the best outcome. I would not consider myself a full fledged wrencher, I can change plugs, set timing etc. but not much more, however the Vintage Air install was not as tough as I expected.
Good Lick,
Bill
Good Lick,
Bill
Sorry gdh, forgot to add, I live in NW Florida and last summer on a day in the upper 90* range, my system was blowing around 40* (can't fully remember) air. Many days, once the car has cooled down, I will run the a/c on less than full force.
Install in 78, I'll add to rant
The install was not plug and play by a long shot. Lots of improvements to kit could be made but they probably won't. They don't make a kit for 78-82 so I got the universal. I just sucked it up and forced everything in. Lost the glove box and the controls for the universal kit I used looked like they belong on a lawn mower. For what these kits cost they could have provided a few extra types of hose styles.
Once I received the extra hose, I was able to tuck next to the driver console, and install the center bezel fine. it pulled though and installed with some persuasion. I think the 2 center hosed should be about 6-8 inches longer, and then they could be hidden and routed better.
But now it is in, so next will be to test it.
