What is the number on 1970-72 LT-1 engines?
I am trying to find out what the cast number for 1970-72 Corvette LT-1 engines
I found one car with a 3970010 engine block that said it was a LT-1 engine
Is this correct?
Is this correct?
Received 1,469 Likes
Cruise-In II Veteran
The 3970010 block was cast in the millions by GM at all three engine plants over a 10+ year period and used in virtually every car, truck, industrial and marine application during that period.
Obviously only a minute % ended up as LT-1 engines.
As always, all engines that have become separated from their original cars 'came from a Corvette'.
My point is that i was sure that the 1970-72 LT-1 engines would have a number that was only for the LT-1 engine blocks
But from what i can tell it does not look like that
I have a 3970010 engine block and i know that this block came from a truck so there is nothing new for me about the fact that the 3970010 block was used on a lot of different cars
You asked for the casting number. Both of us confirmed that it is 3970010 .
If you were asking what stamp pad codes were used for LT-1, that's very different. Each engine spec had a unique code- but you already know that from your C2 experience.
I just thought that the 1970-72 had a casting number that only was on the 1970-72 LT-1 engines.
What is the most easy way to stell that it is an LT-1 engine block?
The differences in the LT-1 engine and the other Chevy small block engines were the internal and external parts assembled to those [identical] engine blocks. There were some machining differences also...for Corvette-only features; but the block CASTINGS were the same.
Threaded holes for mounting the plug wire shielding, for example...
