Good single din radio for c3?
Looking for info on what's good currently for single din radios. I currently have a Model One from retrosound but it drains the battery after a week, making it pretty useless, lol. In any case, I want to try and replace it with a real radio, like a pioneer, kenwood, etc. However, I haven't really kept up with what is currently good and what's junk. I would prefer not to have to add an amp as well (at least to start), so having good power onboard would be a plus.
I've also seen those units that have the touch screens that slide out, anyone have any experience with those? They look cool but they also look like they may be an accident waiting to happen (i.e. motorized screen breaks).
Anyone have any issues with length of the radio? The model one didn't really have any length issues, but I know that most radios are a lot longer than the model one.
Thanks!
Thanks!
Thanks!
Thanks!
I went with this radio, mainly because it was designed to fit a Corvette. New USA 630 II 300 Watt '68 76 Corvette Am FM Stereo Radio iPod USB Aux Inputs | eBay
It also has the look of old...until you power it up. I've done a mod involving the USB/MP3 port on the radio by putting it and a few other items in my ashtray. With 2 dash and 2 kick panel speakers the only thing lacking is bass. I doubt it's the 75 watt per channel they rate it at, but it sounds good.
Do you have a Single din hole or do you have the original center console plate. I looked at some of the single din's that have the screen that come out of the unit. After lots of measuring all that I checked would end up covering some of the Gages so decided on a single din I replaced the center console plate with one made for a single din. I going to use the Pioneer DEH-X8500BS, But it depends on what features you want. Some things I want is Blue tooth, Pandora, color changing, Aux USB port. This unit has them all. I will be running a 5 channel amp so the output power was not important. My gages can change color so wanted to be able to be the same color as my gages. I use the USB port for a mini ipod for my music. If you go on cruchfield.com you can pick what fits your needs.
I used to have a Kenwood Excellon and swapped in an Alpine. Much better sound as far as I am concerned. I am also running an Alpine amp, front dash speakers are Alpine with rears being Polk Momo 6.5's. Whatever one you choose the usb option is so much better than hauling cd's around.
I have the original plate but I'm going to order the single din hole one. The 8500 was one was looking at tonight. Btw, do you have that color changing kit from that Atlanta shop? I can't get ahold of them, I'd love to order that but haven't been able to get ahold of anyone.
All parts are available on line.
I have a Richmond 5 speed with a Long shifter. the Hurst stick is a bolt on. Will most likely work with any Hurst shifter as well.
http://www.ebay.com/itm/HURST-5387201-REPLACEMENT-CHROME-SHIFTER-STICK-6-3-8-Long-Handle-/301082724110?pt=Motors_Car_Truck_Parts_Accessories&hash=item4619edc70e&vxp=mtr
thanks, its a Hurst shift stick for a 5th gen Camaro. Part number 5387201.
Hurst 5387201 Replacement Chrome Shifter Stick 6 3 8" Long Handle | eBay
Tx
vetfever
I had an automatic transmission before I installed the Richmond, so I have nothing to compare it to really, but it shifts smoothly with little effort.
[QUOTE=taylor34;1586034067]Looking for info on what's good currently for single din radios. I currently have a Model One from retrosound but it drains the battery after a week, making it pretty useless, lol.
Most any electronic tuning radio will drain your batter to some extent. They have a built-in memory circuit that constantly draws a minute amount of current to maintain all your station and tone/balance/fader settings. My Battery Tender Jr. keeps me juiced up
[QUOTE=pacecar620;1586044372]
But after a week or two? That's what kills me is that I drive my car on the weekends mostly, and when I go to drive it the battery is dead quite a bit of the time, lol. But that is a reasonable suggestion, and perhaps worth looking into (well at least until the model one dies on me a second time).
Btw, what is up with all the single din head units looking like they're from the mid 1990's? If you put them all in a row, I wouldn't be able to tell which one was the newest one. They all using the same black face with some sort of multi-color led technology that started coming out in the mid 90's...hasn't anyone come up with anything better in 20 years? Kind of surprising. The double din units on the other hand look light years better than they used to.
[QUOTE=taylor34;1586046632]
I have 2 vehicles that have single din systems in them and sometimes its a month or two so between starts. 1937 Dodge PU and a 93 Firebird, The bird also has a alarm system that has the flashing light.
I never have issues starting them.
You might have something else draining your battery.
[QUOTE=Tim 1973;1586046774]
I didn't have battery issues until I installed the radio...and now that I've disconnected the radio, I stopped having issues. So I'm reasonably sure it's the radio, but it could just be a coincidence.
[QUOTE=taylor34;1586046907]Might be with that unit or just that model...
you should be able to let it sit at least 30 days with out the battery dying.
have you had your battery tested recently?
