has anyone
Old Apr 2, 2014 | 10:41 AM
hardlanding's Avatar
hardlanding
Default has anyone
ever found the bird cage not to be rusty? every pic i see its rusty makes me cringe
Old Apr 2, 2014 | 10:45 AM
MrJlr's Avatar
MrJlr
Mine is clean! Windshield change, saw zero rust
Gotta love a California car that's always garaged
pauldana's Avatar
pauldana
mine.... California car...... no rust ANYWHERE... :-)
Old Apr 2, 2014 | 10:46 AM
pauldana's Avatar
pauldana
must have beat me by 20 seconds Jeff!!!! :-) lol
Old Apr 2, 2014 | 11:02 AM
MrJlr's Avatar
MrJlr
Old Apr 2, 2014 | 11:19 AM
F22's Avatar
F22
No rust here in California! (But plenty of little gremlins living in my Corvette!).
Old Apr 2, 2014 | 11:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...ever found the bird cage not to be rusty?...
Yes.
Old Apr 2, 2014 | 12:01 PM
wisoutlaw's Avatar
wisoutlaw
Mine was in excellent shape. 1969 Michigan car, parked in a heated garage from 1984 to 2012. The garage was seldom opened so little moisture got in.
Old Apr 2, 2014 | 12:51 PM
Capkunu's Avatar
Capkunu
Surface rust on my '76, but no rot or holes (other than one 3" section on the radiator support which was repairable).
As already said, if they're not in the high snowy country, Cali cars are comparatively less rusty.
Old Apr 2, 2014 | 01:20 PM
Snoopysvet's Avatar
Snoopysvet
Mine is a Calif car too, other than some surface rust she is clean, except under the radiator like yours. I wonder why?
Old Apr 2, 2014 | 01:51 PM
Capkunu's Avatar
Capkunu
In my case, the rot was directly beneath the drain plug. This suggest to me that, over the years of (hopeful) maintenance, repeated contact with drained fluid affected that area more than the surrounding parts.
When I discovered the problem, I hammered and tapped all around the support, breaking away the rotted 3" cross piece from the lower portion. After determining that everything else was still solid, I cleaned it all off with solvent, then made a fillet from MarineTex, bolstered with several layers of biaxial fiberglass cloth and an additional layer of epoxy extending beyond the fillet. For 'CYA,' I added some fillets in the vertical portions which looked as though they may eventually begin to fail.
Although I believe the repair was effective, I consider this a temporary fix. At some point in the future, I'll replace the entire support.
Old Apr 2, 2014 | 01:57 PM
Haggisbash's Avatar
Haggisbash
Mine was the same as Snoopyvet and funnily enough I was thinking the same thing when I washed the car. I believe that when the water drips down inside the body from around the headlights and front of the hood it pools by the bottom of the radiator support especially near the its corners. This coupled with no internal rust protection from the factory means they become rust prone.
Perhaps a drain hole strategically placed under the support would help? I blew fish oil through the inside of the support on my car to help keep the rust away.
Old Apr 2, 2014 | 02:04 PM
army's Avatar
army
What did your car smell like after that?
Old Apr 2, 2014 | 02:12 PM
Haggisbash's Avatar
Haggisbash
Hi Army, with the modern versions of fish oil rust protection the smell is not noticeable after it has dried, at least to me anyway
Old Apr 2, 2014 | 02:16 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Mine is still that fugly green color. No rust at all, luckily for me, because I didn't know a thing about Corvettes when I bought it twenty years ago, out of dry storage.
Old Apr 2, 2014 | 02:20 PM
Capkunu's Avatar
Capkunu
That makes a lot of sense. The unit seems especially vulnerable to moisture from that area.
I like the fish oil remedy. Probably helps with the engine's cholesterol level too, eh?
Old Apr 2, 2014 | 03:00 PM
jcloving's Avatar
jcloving
Small surface rust on my birdcage. A NC car for its whole life.
To has anyone
Old Apr 2, 2014 | 03:05 PM
Snoopysvet's Avatar
Snoopysvet
Never knew about fish oil as a rust preventor
Capkunu - thanx for the tip
Old Apr 2, 2014 | 03:31 PM
wisoutlaw's Avatar
wisoutlaw
That's why you never see rusty fish!
Old Apr 2, 2014 | 03:34 PM
68/BB's Avatar
68/BB
Mine is a deep south car and has a pretty clean windshield frame, birdcage and frame. Having grown up outside Detroit and living many years in the Midwest (Detroit/ Cleveland/Chicago) before I moved to SC; I am very familiar with the rust issue on ALL cars that spent much time up there. Assuming they were driven year round. Right after we moved here in 2000 I took my Cherokee, that I had brought down here from Ohio, into a shop for some exhaust work. Guy puts it up on a hoist, see the rusty undercarriage, and says, "What the heck is that!? Has this car been sitting in a lake?" I say, Nope, its just from NE Ohio.
