82 RestoMod build LS1/t56 SuperPowers
Hi all,
want to thank everyone for all the great and valuable info.
I bought a beautiful silver/silver non CE car from LastC3AZ here on the forum, and recently picked up a non complete build 81 with a ton of parts.
Did the reading and checked out Josh Powers at custom image corvettes...and decided to send both cars and parts to him for the build.
1) He is pulling the body, welding the frame up and powder coating... looking for colors.
2) have the VBP big daddy super combo, brakes/ suspension that prolly will powder in red...like another member did here...and the brakes too..
3) have a 19/18 inch wheel/tire combo to powder coat in dark grey
4) heads/cam/intake combo for the ls1 with f body pan/ ls6 oil pump/ ls7 lifters/etc, etc... looking for 450 rwhp..(looking for this combo now)
5) have all the other stuff...vintage air serpentine ls1 set up, alum dual fan ls radiator for swap, straight neck water pump, bla, bla..
6) considering mike dyer billet mod for the alum diff.... has anyone here done that for a 80 thru 82?
7) need a t56, with proper mods for 600 hp
again, thanks for all the great write ups...on swaps, etc..
oh..just had the interior done... will post before and afters on that too
Hi all,
more parts pics
and more stuff needed for ls swap...
all suspension coming off.. the VBP a-arms etc.... powder coat red
body coming off .... josh is doing power book welding up of frame...and powder coating charcoal or black...
wheels off the yellow car going to match powder coat to frame..charcoal or black..
also powder coat the brake calipers (currently black) to red...from the VBP c5 brake pkg..
yellow 81 parts car
current parts that i've got...
still need a bunch...ugggg
Big Daddy Performance Plus Combo 80-82 (suspension front & rear.
Rear Bumper Retainer Kit 79-96
1982 Corvette Fiberglass Rear Bumper
Custom LS Radiator and Electric Fan Kit
LS1 Hot Cam and LS6 Valve Springs
LS1 Ignition Coil
LS1 F Body Oil Pan Kit
Fuel Filter/Regulator Kit
Electric In-Tank Fuel Pump
LS Front Runner Drive System
Gates 20676 Lower Radiator Hose
Goodyear 61351 Upper Radiator Hose
GM LS1 Front Engine Cover Crank Seal
GM LS1 Front Cover Gasket
GM LS1 Valve Cover Gasket
GM LS1 Intake Gasket Kit
AC Delco Oil Filter for LS1 Engine
Limited Slip Differential Lubricant
CAM Pre Lube
80-82 Differential (Rebuilt) 3.70 Ratio
Electronic Throttle Pedal
LS6 Throttle Body
MAF Sensor for GM LS6 Engine
LS1-LS6 Adapter Cable
4L60 Transmission Kit
Corvette C6 Power Sport Leather Seats, Black, Heated
18/19 Corvette C6 Z06 Chrome Wheel Rims for C5 1997-04 (4)
Wiring Harness
Pilot Sport A/S Plus Ultra High Performance 245/40R18 (2)
Pilot Sport A/S Plus Ultra High Performance 285/35R19 (2)
LS1 Ignition Coil
CAM Pre Lube
LS6 Throttle Body
Wiring Harness
82 interior after
Thanks Cwerner and Brent !!
I'm excited to get it done... Josh gets the first car this coming week....!!
Cant wait for the LS and 6sp !!! heard so many good things about the manual
look what showed up today
427...
427...
