Temperature Sending Unit... How to Repair If you Dare
Losing connection at temp in the sending unit wire ? Full left (like mine) is lack of signal... If you're confident that the connection at the motor is good and tight... Could be the connection at the gauge? Or perhaps the wire running between both has a rub through the casing somewhere and could ground out? Would that provide the symptom?
Absolutely a good guess... Perhaps it's grounding itself out on the side of the unit and interrupting the ohms signal? Think Wilcox pointed out there's a cardboard tube in there... Perhaps it deteriorated and is allowing grounding? All signs would point towards the sending unit in my opinion... I'm trying to track down a new one myself as my temp gauges haven't worked since I bought my vette last summer... ;-)
You can use a flasher to test Fuel gauge, Oil pressure Gauge, and Temp Gauge. If you purchase a new one.... no way would I toss the old one. What you should do is remove the sender, clean both the contact and the threads and test for ohms. A cold sender should have 600 or more ohms. If you get a reading after it's clean re-install it by putting Teflon tape, two turns on the first couple of threads only. Teflon is not a sealant, it is a lubricant to assist the brass threads in seating.
Odds are against you that a new one will work correctly..
Willcox
Willcox
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I wanted to update this after talking to our electrical engineer... The oil inside the sender is not something to play around with. It's more than likely pyranol which contains pcb's.
So... After striking out with the 'quick local' search for finding my sending units... I would like to find out what I DO have, and where I can buy new ones... Don't have a lathe, so I'm not going to try and rebuild mine... But now I'm curious how to find the ones I need...
I'm hoping I don't have to pull em out to find part numbers.. This is the temp gauge sending unit on the drivers side...
That second pic isnt an oil temp gauge...looks like a temp. activated fan switch.
Oil temp would be in an oil passage, not a water passage in the head.
Former Vendor
@ MaFry.
I have a tester here for that, but for home use.. The test is a simple one.. you use a double A battery and solder wire ends on it. If you touch one end to one terminal, and then briefly touch the other end to the other terminal the gauge should deflect... switch the battery around and it should deflect the other way.
If you hold the battery on too long you'll cook the gauge.. so just a quick touch and it should answer your question.
#33
Former Vendor
Water temp is no a problem except it won't give you an accurate reading... this one, 81-84 is closer than any of the other temp gauges I've tested. If it doesn't read correct I have a fix coming for that soon...
http://willcoxcorvette.com/product_i...oducts_id=5014
The oil temp is off the charts high, and there is an imported version with the gauge that is cheaper...
http://willcoxcorvette.com/product_i...ducts_id=27961
The aux. fan switch is discontinued..
http://willcoxcorvette.com/product_i...oducts_id=6586
and looked like this.
#34
Former Vendor
As mentioned above, I've tested every brand of sending unit available on the market place and I've even had manufacturers tell me their unit had the oil in them just like the originals... And when I pop the cap off I find them dry.
Most manufacturers (aftermarket and repro) don't know the issue isn't the oil.. (Yes I'm sure the oil helps conduct heat through out the entire sender) The issue is the Thermistor in the sending unit not being calibrated correctly. The temperature gauge is a non linear gauge and so the Thermistor must follow this same pattern...
When you are fixing a car in your shop, your name stamp kind of follows this repair. If a customer comes in wanting a temperature gauge to read correct... the only solution (for now) is to do as we've done above. While it might not be pretty... it works! Sadly the equipment required to do this is not something most would have in their garage though.
Since the gauge is non-linear, placing resistance in the sender wire is not the answer... Aftermarket senders tend to read cold... And to make the read higher you have to remove resistance. (put a resistor inline) Even if this were possible, it would make the gauge accurate at only one temperature and not over the entire scale.
So.. Where is all this going...
There is a solution and I will have it soon. I posted a picture of the last prototype on the fb page a few weeks ago and I’m waiting for boards right now. When the boards arrive the fix for the reproduction senders will be finished.
Willcox
#35
Many thanks! And I will do as you suggested and try to clean em up as best I can... Will also try and run some 'tests ' on them when I have them out... See if I can effectively bring these units back to life... ;-)
#36
Former Vendor
Some aftermarket senders go berserk when they get hot... this may be your problem. Original senders are kind of easy to ID by the markings.
Willcox
#37
Thanks. I'm going to replace it and see what happens. I haven't removed it yet, but from the outside it appears original. It was moved to the intake manifold, presumably because the AFR heads have the smaller threads.
#38
Former Vendor
#40
@ MaFry.
