1977 Corvette Mirror
Old 07-22-2014, 03:52 PM
Alex36
8th Gear
Alex36's Avatar
Default 1977 Corvette Mirror
Just got a 1977 Corvette! The drivers side mirror is loose. Can the mirror be taken apart and tightened up? The mirror moves around while driving.
Old 07-22-2014, 07:34 PM
Doug's 77
Doug's 77's Avatar
Yes but it depends what part is loose. Take the door panel off roll the window all the way down and there are two nuts that will remove the mirror and gasket from the door. Under the gasket there is two more screws that hold the mirror head together. Those screws may be loose causing the mirror to move or the ball and socket may be worn out. Just make sure when you put the mirror on the door you have the gasket turned the right way or the mirror will be tilted up toward the window.
Hope that helps you out.
Old 07-22-2014, 08:28 PM
Kris Tunetso
Kris Tunetso's Avatar
From what I've gathered in the short time I've been a member here it's likely the ball/socket: if it is that for you then no, it can't be fixed. Most just get the mirror oriented the way they want it and drop some superglue on the ball, sticking it in place.
Old 07-23-2014, 05:37 PM
news2me
news2me's Avatar
My right side mirror is doing the same thing. I like your idea set the mirror to my liking, put on a little drop of glue and I'll be go to go.
Old 07-23-2014, 10:35 PM
billcarson
billcarson's Avatar
on my passenger side mirror i just said, "screw it"! so that is what i did.
Old 07-25-2014, 10:58 PM
Alex36
8th Gear
Alex36's Avatar
Thanks. Im going to get into it sat. Thanks for the info.
Old 07-26-2014, 08:09 AM
birds69
birds69's Avatar
i think this is what you need to do.
http://forums.corvetteforum.com/c3-g...oday-pics.html
Old 07-26-2014, 01:39 PM
Kris Tunetso
Not my idea, just something I've read that others have done.
Hadn't seen that before. Way better than superglue.
To 1977 Corvette Mirror
Quick Reply: 1977 Corvette Mirror
