Show us your NO or LOW COST HOME MADE do it yourself stuff C3 CORVEtte
#161
76CSRvette (11-11-2016)
76CSRvette (11-26-2016)
#164
Received 3,136 Likes
brake/fuel line clamp removal tool
Sure, why not
Cut the end off cheapo 1/2" socket and weld it to a strip of metal for a handle
Fits up over the lines and onto the bolts holding the clamps in place while the body is on. some 75 degree drop boxed end wrenchs work but don't get into all spots
M
M
The following 2 users liked this post by Mooser:
76CSRvette (11-26-2016),
Majoho (11-20-2016)
#166
Received 3,218 Likes
Got this idea from a friend of mine-
Colored electrical tape- less than $5 at Harbor Freight
Wrap some on the cord at the tool-and then at the end near the plug.
Next time you have several tools running- you'll know which is which with little or no thought!!!
DSCN4144 by Richard Hayes, on Flickr
The following 3 users liked this post by Richard454:
The following 2 users liked this post by The Punisher:
Majoho (11-20-2016)
#168
76CSRvette (05-19-2017)
#170
Tractor tail ligjts led with ring
Some trailer led lights simple mod bought the tail end connectors for plug and play. Lost my phone with pics of installation and lights on car is still sitting waiting on more minor mods and suspension upgrades.
#171
Here a couple cheap mods I did a while back
1st is the gas strut instead of the old hood prop. Strut cost about $20 and made the bracket from parts of the old hood prop
2nd I had a courtesy in the back so I took it out and installed the corvette symbol projector from eBay think it was $12. When you open the door it's comes on
The following 4 users liked this post by Danny.reamer:
#172
#173
76CSRvette (05-23-2017)
#176
I did this on the underside of my hood. All you need is someone who has a graphic cutting machine and some vinyl. I bought 3m brushed metal vinyl do do this it is a dark reflective vinyl that is heat resistant and made for automotive applications. I wish I knew how to post a video because the picture doesn't do it any justice on how cool it looks. It just looks black in the picture but in a video it shows how at certain angles it almost disappears and at others it pops out.
The following 3 users liked this post by Danny.reamer:
#177
I don't have pictures taken, but here the procedure.
Mission; The speakers in the 82 CE suck so bad, the prior original owner DUCT TAPED the speaker cones!!!!
So I get on Amazon and look for speakers...all four, circa 2017. Fronts were no problem other than having to make a tool to get them out! Rears, Amazon pops up with a 'these speakers don't fit your car! (6x9') to which in my old curmudgeonly way, I say to myself
"what does Amazon know about old corvettes" and order them out of spite! lol
Okay they didn't fit!
But not in the way you think. snort!
Old 6x9's have TINY magnets...new modern speakers have GIGANTIC magnets.
So they would not recess correctly with the Erector-Set brackets (okay I'm old, Deal!) Chevy made for the late model C-3's (apparently a 3:00 am on Christmas Eve by the 'D' team who had no accrued vacation time).
After pondering for a while I mounted the speakers in the GRILLES (they fit perfectly)
Then of course realizing that the huge magnets would not fit into the recessed back corner pockets...SWAPPED THEM. Side to side and rotated 90°. So the left went to the right, etc and then instead of
mounting them as original with the 9" flat/ horizontally so-to speak...I rotated them so they would utilize the hump cut-outs VERTICALLY. I bagged the Erector-Set brackets as not needed. (along with the 'ram-air flapper' that is the 'air obstruction flapper' really).
Upshot, they work, sound and look great...what does AMAZON know! lol.
76CSRvette (01-10-2018)
#178
Since I'm not in the kitchen much, except to eat....I found out about this stuff covering some leftovers in the refridge-
I don't know how much it cost- but somehow I paid for it...
Quick Google search about $6-7 for 140sq/ft
It works GREAT for sealing all sorts of stuff.
I was cutting and soldering wires around my open intakes - needed something to seal them up.
Much easier than tape!!!
When you put pressure on it- the adhesive is activated-just rubbing it down with your hand and it holds well. When you peal it up- no residue.
Looks like it would be absolutely great to cover surrounding places you don't want paint over-spray...
Or scraping gadget material off and keep it out of the engine...
Or how about running a buffer and want to keep the spray from windows- tires- trim- you name it.
Another thought- at the drag strip to cover the quarters for easy rubber removal...
The following 2 users liked this post by Richard454:
76CSRvette (01-10-2018),
Rescue Rogers (02-02-2018)
#179
#180
I just did this and used a socket that was 1.25" tall. Got the idea right here.
