Show us your NO or LOW COST HOME MADE do it yourself stuff C3 CORVEtte
Old 10-31-2014, 02:11 AM
AboveTheLogic
AboveTheLogic's Avatar
Custom gauge panel, the gauges weren't cheap but the clear plastic and black plastic paint was:
Made a fan shroud out of a baking sheet. The large black fan is a junkyard fan that lasted me about a year. The baking sheet was about $20 and the Syclone fan was about $110 from amazon.
76CSRvette (01-21-2016)
Old 10-31-2014, 09:50 AM
Jamess411
Jamess411's Avatar
Love the baking pan mod…
Old 10-31-2014, 10:13 AM
AboveTheLogic
Thanks, I was proud of that one! I spent a good amount of time looking into several ways of making a shroud. I don't know who it is who gave me the baking sheet idea, but I measured the radiator surface and found that an 18"x26" sheet should fit over it. Found it on amazon:
Amazon.com: Winware 18 Inch x 26 Inch Aluminum Sheet Pan: Baking Tray: Kitchen & Dining Amazon.com: Winware 18 Inch x 26 Inch Aluminum Sheet Pan: Baking Tray: Kitchen & Dining
It fits very well!
I notched the pan, drilled holes in the radiator lip, and used small nuts and bolts to attach it to the radiator.
Old 11-01-2014, 02:51 PM
brent319
brent319's Avatar
C3 of Year Winner (appearance mods) 2019
I made some turn signal indicators and high beam indicator with a $1.50 clear rod from Menards and a few LEDs.
Old 11-01-2014, 04:12 PM
AboveTheLogic
Ha! That is cool.
Old 11-01-2014, 08:25 PM
SB64
Support Corvetteforum!
SB64's Avatar
Default Supports
Okay so here is what I had to make up in order to install the rear leaf spring in my 69 while doing an off body restore. Try to jack the end of the leaf spring with no body wait. The entire frame was lifting.
Solution below
This allowed me to jack the end of the leaf to install the bolt while the wood pushed down on the frame.
Old 11-06-2014, 03:28 PM
76CSRvette
76CSRvette's Avatar
Default mesh grill
I know it may not be everyone's cup of tea...
I bought this mesh for like 2 buck at this import/aftermarket shop to complete the 25 dollar minimum purchase.
I didn't use any wire cutters i just bent the thing a million times to cut off piece the size i needed using old grill as a template just cutting about 1inch more. My originals were a little brittle and broken.
I think they look cool next step is led signals down there and some mesh for the side gills
interpon (04-12-2021)
Old 11-06-2014, 03:32 PM
76CSRvette
76CSRvette's Avatar
Better pic
M Pete (12-26-2016)
Old 11-06-2014, 03:37 PM
keithinspace
keithinspace's Avatar
I'm digging the Engrish:
ALUMINUM FOR TUNING
This is the Aluminum net to make your car more sportive, to fit on the front of your car.
So...is your car more sportive?
It does looking cool, though.
Old 11-06-2014, 04:34 PM
76CSRvette
76CSRvette's Avatar
Default Mesh gutters
ALUMINUM FOR TUNING
yeah its more sportive
For the money i can't complain. once I get the middle open it'll be more sportive there too. I also used it to replace the chicken wire in the wiper compartment and added some silicone to make it some what flush and sprayed it with some sound deadner rubberized spray to see if it helped with leaks and so far after rain nothing.
Old 11-07-2014, 01:18 AM
MyRed69
MyRed69's Avatar
My free sand blast cabinet. An old stereo cabinet, I just cut two holes in the side for my arms and one for the hose. The sleeves are old shirt sleeves, it works great for most of the parts i took off the car.
My "free" from scrap powder coating booth with rotating rack that goes with my $15 thrift store dedicated powder coat oven. Notice the oven rack in the booth? slides right out and into the oven. The rotating assembly is the same size as the inside of the oven so when i hang stuff in the 'booth' I know it'll fit in the oven.
The following 2 users liked this post by MyRed69:
76CSRvette (01-21-2016), interpon (04-12-2021)
Old 11-07-2014, 01:43 AM
76CSRvette
76CSRvette's Avatar
very cool and nice set up.
Old 11-07-2014, 02:01 AM
  #33
Jamess411
Jamess411's Avatar
When you are done with the cabinet send it to me so I can do my brackets too )
Old 11-07-2014, 06:04 AM
  #34
SB64
SB64's Avatar
Now that is a cool setup. All the parts look great. Neat idea.
Old 11-07-2014, 03:35 PM
  #35
imariver
imariver's Avatar
Originally Posted by C3Hawk
Speaking of brakes, like Mick 71, here are the "precision tools" I use to keep the pistons in the calipers when I am working on them. Nothing but the best in my shop!
Do you have a part # for those?
Old 11-07-2014, 03:41 PM
  #36
69L46vert
69L46vert's Avatar
I made my own No.1 body mounts, seat belt reinforcements and the two brackets that hold the reverse lockout cable to the trans. Just because I didn't want to wait a week for parts to ship. Not because I'm a cheapskate. Really.
Old 11-07-2014, 04:48 PM
  #37
SB64
SB64's Avatar
Hey Rick I know you did because you a very handy.
To Show us your NO or LOW COST HOME MADE do it yourself stuff C3 CORVEtte
Old 11-07-2014, 05:08 PM
  #38
69L46vert
69L46vert's Avatar
Thanks Roger. Here are some pics of a bearing setup tool that I made to rebuild the trailing arms. I made a knockout tools for the shock mount and spindle, a rear spindle bearing install tool, and race installers for the rear spindle bearings but don't have pics Rick
I like your idea for installing the rear spring. I had trouble with that and wound up using chain. It was a little dangerous that way but worked out ok.
Old 11-07-2014, 05:32 PM
  #39
SB64
SB64's Avatar
Nice Rick, very nice.
Old 11-07-2014, 11:24 PM
  #40
MyRed69
MyRed69's Avatar
If you're near Tampa or Ft. Myers, come get it... I'll even loan you the powder coat stuff.
Quick Reply: Show us your NO or LOW COST HOME MADE do it yourself stuff C3 CORVEtte
