Hi,
I believe while the pipes are the same there's a slight difference in the STOCK 73 muffler design so the 73 requires a 1 year only chrome tip different from the 70-72 chrome tip.
Regards,
Alan
To me this kind of question is about what you desire,
in general many parts like exhaust from 68-82 will interchange, okay before you start flaming me, they will interchange with mods ranging from none to big... for example a set of hooker side pipes , yeah , I know afteramrket, will fit 68-82 but the job will change depending on year...so if you are cool with mods it's okay but if you are more into the stock way the car came factory then you are stuck....
the 73 mufflers are round and the 71-72 are oval. also the chrome tips are different because the discharge from the muffler is in a different location.one is more centered while the other is to the side. if you want to use the oval type muffler on your 73 use the 71-72 tips. this allows the mufflers to be more hidden than stock 73 mufflers.
